Latest version of Parts Finder
  • MBZ6301
    • Aug 2016
    • 42
    Does anyone know how to find this on Octopus?
    It's rare that we have to resort to using this, but on the odd occasion it's handy. However recently the files downloaded for each model don't seem to open. I can choose which area to look at, for example laser unit/pcdu, but upon opening them it's just blank.
    Is it a version issue perhaps? Latest I have is 2.3.1
    Cheers
    edit - Not sure why the image shrank so much
  • Polarbear
    • Feb 2012
    • 1070
    Re: Latest version of Parts Finder
    Hi
    Interesting thing is, I just checked Ricoh Octopus and the latest version is 1.8.2 dated Feb 2021.
    If you do a search from the main search bar using CATALOG EXPLORER as the criteria, that comes up.
    Installed it, and then it complained about an expired license. There was a file called Regene which is a batch file one has to run to fix this.
    After I downloaded a 3d parts catalog for the SP220SNw as a test and it works. What is a pain though is that you have to select a section and can only view that section. If you wish to view another section, you need to click the house icon and select the new section from the list.
    Otherwise is seems to work.
    Press the GREEN button!!
    • luca72
      • Oct 2017
      • 1745
      Cheers
      [ATTACH=CONFIG]50152[/ATTACH]
      hi, I use it quite often, some partlists, work with the old catalog explorer, others, with partfinder, the files, are not compatible with each other, so you must have them both if you use this kind of approach to 3d part catalogs ... me I downloaded it from the ricoh portal
      "I'll be back"
      • MBZ6301
        • Aug 2016
        • 42
        I've used that program in the past, so thought I'd give it a shot again on this fresh PC. I also had the license error but the update on the same page sorted that.
        I'll give it a shot shortly pal, once I find something​ it will open
        • reded
          • May 2023
          • 1
          Good morning everyone,
          I have a question. Is the Parts Finder app available for MACos?
          • dalewb74
            • Feb 2018
            • 1125
            once you download the parts finder. make sure to unzip all files to the same folder. then open the parts finder by navigating to that folder. i just name the folder whatever model it is.
            • Sashko
              • Oct 2009
              • 110
              Cheers
              Use this word "partsfinder" for serching. Without spaces!
