MPC2003 white image repeat
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Customer with an MPC2003 called, complains that on his prints there's a white repeating image on it.
    See pictures.
    Just a month ago a new PCDU K installed.
    Rarely seen this, something with the charge?
  • COPIERMAN
    • Jun 2009
    • 559
    Re: MPC2003 white image repeat
    could be a couple of things. Fuser /image transfer assy / i start with printing counter report or smc print out to see it if has same problem those are internal print generated and go from there.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by GeorgeBest
      Hi,
      See pictures.
      thanks in advance [ATTACH=CONFIG]50168[/ATTACH][ATTACH=CONFIG]50169[/ATTACH]
      Was it a new complete pcdu ie pcu and dev assembly. Or was it taken out of another machine
      Regards Mark
      • 8T2
        • Aug 2015
        • 257
        This and also full beam and/or checkered test pattern on full colour followed by a blank test pattern to try narrow it down to specific colour or fusing
        Sent from my WAS-LX1 using Tapatalk
        • GeorgeBest
          • Jul 2009
          • 526
          was complete new . . .
          • BLADE
            former propeller tester
            • 478
            maybe the end cap was left off the new pcu
            • emiliorsg
              • Jul 2018
              • 141
              Looks like fuser unit problem. How many copies has the unit made?
              • GeorgeBest
                • Jul 2009
                • 526
                changed the ITB and fuser, no results, seems like it is only on the left side . . . see pictureswhite image1.jpgwhite image2.JPGwhite image3.JPG
                • emiliorsg
                  • Jul 2018
                  • 141
                  Try a bk imaging unit and make sure the back plate is installed. Seems to repeat the error with a diameter similar to the drum.
                  • GeorgeBest
                    • Jul 2009
                    • 526
                    changed the fuser, no result
                    • Blizzoo
                      • Aug 2013
                      • 611
                      Faulty erase lamp? Speaking from experience with a similar issue on a different brand cause by bad erase lamp/LED
                      • Drivee
                        • Nov 2020
                        • 322
                        the name of this is negative backgraund, the problem is in most causes erese lamp/PCR or DEV unit. DEV is new? Then try to play with OPC.
                        Someone also say that issue can be printer driver.. I dont belive that this is your cause as backgraund is not so visibile.
                          • 37628
                          MP C2003 does not have any type of erase lamp.
                          • RMC8112
                            • Nov 2019
                            • 38
                            Did you try cleaning the LSU glass?
                            • luca72
                              • Oct 2017
                              • 1792
                              how is it not there? there is one in each slot of the pcdu, at the bottom right ... but in any case, maybe that is not the problem
                              "I'll be back"
