MPC2003 white image repeat
  • Drivee
    • Nov 2020
    • 322
    #16
    Re: MPC2003 white image repeat
    MP C2003 does not have any type of erase lamp.
    Every laser/led printer have some device which will erese OPC. Is that lamp, PCR or corona wire does not matters.
    • luca72
      • Oct 2017
      • 1778
      #17
      Originally posted by GeorgeBest
      Hi,
      Customer with an MPC2003 called, complains that on his prints there's a white repeating image on it.
      See pictures.
      Just a month ago a new PCDU K installed.
      Rarely seen this, something with the charge?
      thanks in advance [ATTACH=CONFIG]50168[/ATTACH][ATTACH=CONFIG]50169[/ATTACH]
      assuming that:
      complete pcdu is new
      itb its new
      fuser replaced
      I think about:
      - bad discharging lamp
      - wrong values ​​in pcdu installation
      - problem in the contacts in the machine body (pcdu or itb)
      - defective hvt board in black pcdu output patch
      ... and why not? ... defect in the pressurization mechanism of the pressure roller (on the machine)?
      "I'll be back"
        • 37487
        #18
        Originally posted by luca72
        how is it not there? there is one in each slot of the pcdu, at the bottom right ... but in any case, maybe that is not the problem
        If that were true, why are they not listed in the parts catalog or in replacements and adjustments section of the service manual. I checked before I commented.
        • anothertech
          • 1769
          #19
          There is a discharge lamp for each PCDU and that could be the problem. Try turning on the discharge lamp on service mode.
          • anothertech
            • 1769
            #20
            This is a long shot but, could it be that the PCU heater is not working?
            MP C2003-32.pdf
            • Dan G
              • Nov 2014
              • 56
              #21
              at he end of the PCDU is a cover and inside the cover is a grounding strap- if this cover is forgotten (often ) it will cause similar issues
              • luca72
                • Oct 2017
                • 1778
                #22
                Hi Silm, I also checked before answering you, I remembered that there were, but reading your comment, I got the doubt, (if Slimslob says so !!!). then I looked both in the machines, (I have a couple disassembled in the lab), and also in the parts manual, and they looked, now because I'm at home, if not I would attach the pdf of the page ... try to search the pdf "discharge"however they are at the bottom right of the slot
                "I'll be back"
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  #23
                  looks like a (dis)charge problem to me.
                  Transfer issue perhaps.
                  • GIUBOSS
                    • 1435
                    #24
                    I had a similar problem with a 2051, maybe it can help you, the problem was on the laser unit, open it and clean the glasses and mirrors of the polygon
                    • copytrust
                      • Feb 2010
                      • 118
                      #25
                      First go into SP modes and make test patern for each colour this way you can check if you have any drum unit problems, if the problem persist on each colour then you go for transfer belt and anything else.
                      Funny moment with this machine was a newly installed machine after a week i got a call for image repeat and inside the black drum unit on the charge roller there was a squized huge mosquito, how that little f@@@@@ get in there i had no idea.............
                      • Polarbear
                        • Feb 2012
                        • 1070
                        #26
                        I agree, residual image is repeated as residual charge is not removed inbetween images being written.
                        Was the new pcu detected? Did you set the pcu setting to 1 power off and install and then power on for process control?
                        Press the GREEN button!!
