Ricoh Firmware Update Tool!! Oh wait, it doesn't work.
Re: Ricoh Firmware Update Tool!! Oh wait, it doesn't work.
My current 2gb SDSC popped a e24 error. Card Access Error, Reinsert, or Replace. I have ordered a new SDSC 2gb, but maybe a smaller 1gb or 512mb would be a better option. We'll see.
Thanks for all who have given of their time and talents.
I'll update at the beginning of the week.
Then I realized that 2 generous souls had sent me a firmware file, however they were not the same. For my problem, the firmware that ends in 7587 doesn't seem to work. The File type was also ".RFU".
What does work, For my Machine, is the Zip file that ends with 7588. The file type is ".FWU".
KenB did say the 512mb may be too small for the newer IM machines, the single Firmware file that I had didn't use a quarter of the 512mb. It was only 27mb. But your firmware may be different, so plan accordingly.
After all my mistakes, and I got to the Update screen, It took a few times for the machine to respond to the Update button. It ran.
Phase 1 complete.
Phase 2 the Ricoh Firmware Update Tool
After the stock firmware was installed the Update tool status changed. and allowed for the update process.
I was able to update and now it shows as current.
Rebooted and checked the Firmware:
Phase 3 find out what now doesn't work.Module Name Version Part Number System/Copy 1.24 D1475575C Network Support 12.82.1 D1475567W Fax 11.00.00 D1475557S RemoteFax 04.00.00 D1475558H Scanner 01.15 D1475560S Web Support 1.13 D1475561R Web Uapl 1.00.5 D1475562H animation 7.00 D1495564D NetworkDocBox 1.08 D1475568L Printer 1.17 D1655701W RPCS 3.13.29 D1655703J Font EXP 1.00 D1475581 PCL 1.22 D1655706Q PCL Font 1.13 D6415758A PDF 1.06 D1655733F PS3 Font 1.11 D6415763A Java VM v11 std 11.38.01 D1475564B Data Erase Onb 1.03m D3775913 GWFCU3.8-2(WW) 11.00.00 D1495559M PowerSaving Sys F.20 D1475554E Engine 1.40:08 D1475504D OpePanel 1.10 D1471438J LANG0 1.10 D1471438J LANG1 1.10 D1471438J ADF 01.320:03 D7795300K Finisher 01.230:04 D6865301M
Thanks for all who helped.
As far as I can tell none of the other firmware files were changed.Comment
That model machine boots up very slow, I always turn off java if it's not being used, change SP 5730 from 1 to 0.
Then the firmware update starts a lot sooner, otherwise you have to wait quite a while at the firmware screen.
It looks like the update tool did not work very well, your firmware is still old. You may need to obtain the new package firmware and then update it with a larger SD card.Comment
You gentlepeople are great.Comment
Re: i needed firmware for mp3050 and mp4050 smb 3 scan
You want to ask again with some models that actual exist? Like maybe MP 305 and MP 405. Or maybe MP 3054, MP 4054, MP 3055 or MP 4055. Or maybe even the gel jet model GX 3050.Comment
He may have not been aware, but if he even read just the initial post entirely, one would think that would have have triggered his curiosity to PERHAPS try at least one Google search to find out about this mythical firmware update tool (sarcasm again) that was mentioned, but then, if you read some of his history, he's the type that likes to overcomplicate everything!
(like wanting to set up SMB scanning via a command prompt), so I suppose I shouldn't be surprised
