mpc3002 jams with tray 1 paper did not move
  • Mark Bbb
    • Jun 2012
    • 1662
    I replaced tray 1 paper feed unit ass'y with a referbished one (new one way's and paper feed rollers).
    Problem remains.
    I checked the serv manual 3002 & 3001 for details about the paper feed mechanisme, but there is no chapiter "detailed descriptions" there. mpc3000 has this chapiter, but is it the same mechanism?
    Anyone can throw me a bone here? .
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc3002 jams with tray 1 paper did not move
    Do you use the pick up belt D0892830 for mpc3001 or just the AF030085 (as i do)?
    Paper feed rollers:
    AF030090 serie MP4000 GREEN
    AF030085 serie C2800 C3001 C3002 ORANGE
    AF030094 serie C3003 C3004 GREEN
    Paper feed units:Referbish paper feed units
    Replace levers G0652767 & AB011218
    • Mr Magic
      • Jan 2020
      • 29
      Problem remains.
      If the rollers are not making contact with the paper to pull it through, check the solenoid, the door cable/connector or the main board. More likely it's the connector not pushed all the way in.
      • Gift
        • Mar 2011
        • 2459
        These pick up belts were the biggest crap - we also use regular pick up rollers. You might need an additional plastic washer in order to keep that whitish/yellowish rholder thingy properly in place, otherwise it might got stucked and the pick up roller won't move downwards.
        • luca72
          • Oct 2017
          • 1762
          Problem remains.
          hi, try replacing the tray.
          it happened to me that the rear part, honestly made of plastic a bit too light, tends to deform and move forward when the drawer is inserted, and the station operating lever does not work correctly, alternatively (as I do io) you can apply / glue a piece of thick, cut-out plastic to that point on the tray
          "I'll be back"
