MP2501sp - SC520
  • Polarbear
    • Feb 2012
    • 1070
    MP2501sp - SC520
    Good day all
    Here is a strange one.
    MP2501sp service call gets phoned in (have not gone there yet) reporting SC520.
    Service manual says REGISTRATION MOTOR LOCK?
    Machine does not have a registration motor - but a clutch, same as MP2000SP??
    Has anyone come across this one before and what was the fix?
    Thanks in advance.
    Press the GREEN button!!
  • nokktekk
    • Mar 2018
    • 44
    Re: MP2501sp - SC520
    I had one which had a seized PCU. The developer leaked on to the registration bushing (AA082177 BUSHINGIA8:22) and the registration roller could not rotate. I serviced the machine and replaced the PCU. You may want to check this.
    • GIUBOSS
      • 1382
      Originally posted by Polarbear
      Good day all
      Thanks in advance.
      I think it refers to the main engine: 29.AX060502
      DC BRUSHLESS M
      OTOR: MAIN: 24.7W faulty, in case you don't solve with Nokktekk's suggestion.
        • 36689
        Whatever motor drives the registration locks when the registration clutch turns on.
        • Polarbear
          • Feb 2012
          • 1070
          Feedback:
          Turns out the gear in the dev tank that sits between the mag roller and the augers, decided to vacate its location and lodge firmly between the auger gears - hence the motor lock error.
          New dev tank solved the issue.
          Thanks all for the quick replies. Appreciate it greatly.
          • KeviM
            • Oct 2019
            • 324
            Feedback:
            Bit of a common fault on these machines. Hopefully you were able to replace the entire developer tank and not just the gears. The bushings that hold the developer in, have a tendency of leaking with age and wear and tear.
            • Polarbear
              • Feb 2012
              • 1070
              Yup the dev tank was toast....
              Sent from my SM-N770F using Tapatalk
              • KeviM
                • Oct 2019
                • 324
                Excellent stuff polar bear 🐻.
