mp 2000
    • 37641
    #16
    Re: mp 2000
    Originally posted by Gab
    yes, but ihave replaced hotroller with a genuin one. also it looks to me that hot roller is too hot.
    Too hot or too cold for the paper thickness can cause offsetting.
      Re: mp 2000
      +1
      • KeviM
        • Oct 2019
        • 327
        #18
        Re: mp 2000
        Check your hot roller and fuser unit again. Check your temperatures like the other engineers said.. . Then
        If you have another PCDU imaging unit, preferably a good second hand unit, put it in and run about 200 prints. If it stops the repeat image after about 100 prints then you have your answer. Use a different toner as well
        • Gift
          • Mar 2011
          • 2459
          #19
          Re: mp 2000
          And what about the press roller bushings as GIUBOSS suggested? Press roller itself can also loose it's diameter and stiffness over time, especially the "foamy" ones.
          • KeviM
            • Oct 2019
            • 327
            #20
            Re: mp 2000
            Agreed 👍🏼
