mp 2000
  • Gab
    • Aug 2015
    • 677
    mp 2000
    image repeted like ghost image. When making copies it does not appear on every copy . when printing the problem is more intense i replaced hot roller and blade with no result. any idea?
  • 8T2
    • Aug 2015
    • 257
    Re: mp 2000
    Possible to post a sample print of counter page or proper test page? Helps to see distances between repeating image and type of repeating
    Sent from my WAS-LX1 using Tapatalk
    • Gift
      • Mar 2011
      • 2459
      Re: mp 2000
      Nice red light sabre....
      Check the distance between the repeating pattern and compare with Hot Roller / Drum circle length.
      + Check erase lamp
      • KeviM
        • Oct 2019
        • 327
        Re: mp 2000
        Sample print would help alot. Without that the possibilities are
        Cleaning blade
        Hot roller
        Laser unit
        Drum
        Toner (if generic or faulty. This in turn will have an effect on the developer)
        The list goes on
        If you did your cleaning blade and hot roller change then stop the machine mid cycle print, once before it enters the fuser unit and once mid-way through the fuser. That should help determine the cause of the problem.
        • KeviM
          • Oct 2019
          • 327
          Re: mp 2000
          + Check erase lamp
          Whats a red light Sabre?
          • anothertech
            • 1771
            Re: mp 2000
            Google Image Result
            That, or the nice line of red cards the poster has by his name.
            • Wild Bill
              • Jul 2005
              • 774
              Re: mp 2000
              Originally posted by anothertech
              Google Image Result
              Wow, I have never seen red like that...
              Izzy
                • 37628
                Re: mp 2000
                I know of a couple of other members.
                • Gift
                  • Mar 2011
                  • 2459
                  Re: mp 2000
                  Google Image Result
                  yup!
                  • Gab
                    • Aug 2015
                    • 677
                    Re: mp 2000
                    distance of repeated image is exacly the perimeter of hot roller
                    • Gab
                      • Aug 2015
                      • 677
                      Re: mp 2000
                      i am collecting red cards , hope you give me more.
                      • 8T2
                        • Aug 2015
                        • 257
                        Re: mp 2000
                        Is it original Ricoh Genuine Hot Roller? Have had the generics and recoated rollers giving problems straight out the box before especially if the machine is slightly overtoned or pressure roller not 100%
                        • GIUBOSS
                          • 1437
                          Re: mp 2000
                          check the two pressure roller bushings and the thermistors
                          • Gift
                            • Mar 2011
                            • 2459
                            Re: mp 2000
                            Better not, it might break the forum
                            very good hint, totally forgot this one and since Gab figured out the distance of the repeating image is a match with the hot roller, this is probably the cause...
                            • Gab
                              • Aug 2015
                              • 677
                              Re: mp 2000
                              yes, but ihave replaced hotroller with a genuin one. also it looks to me that hot roller is too hot.
