MP C2004ex format HD
  • Tonerkiller
    • Oct 2012
    • 668
    Ricoh guys please help. I have a MP C2004ex that I am sending back for a customer. I am not a Ricoh tech. How do I format the HD?
    Thank you in advance.
    • 37502
    Re: MP C2004ex format HD
    If Disk Overwrite Security System has been properly enabled, you do not have to. In fact any data will have been erased a lot more securely than formatting will do.
    • Tonerkiller
      • Oct 2012
      • 668
      I work with Kyocera, they have a data salinization which gets rid if everything including the address book then prints a page that shows that was done. That is what I am looking for here.
        • 8149
        There is a special SP model that will allow you to wipe the HDD/address book & clear all passwords but since you are not a Ricoh tech you won't know about this.
        You could remove the HDD & format it using a USB caddy in Windows.
        • Elmo
          • Feb 2010
          • 541
          If you have the admin password
          Login as Admin
          Goto User tools - Machine Features - System settings - Admin tools - Page 3 - Erase all memory - select number of passes then erase
          Forgot to mention this can take 2 hours plus depending on number of passes
          I Used To Live To Fix Things Now i Fix Things To Live
