Sc314
  • mfrigault
    • Feb 2017
    • 18
    See service bulletin:
    • luca72
      • Oct 2017
      • 1778
      In octopus there isnt, but its similar to mpc401 bullettin
      "I'll be back"
      • Kotkey
        • Mar 2024
        • 16
        I checked all the contacts, nothing helps. Maybe there is an error in NVRAM? Can I update it somehow? The manual says to upload to SD, load from SD/Is it too late for me to upload to SD? I mean this -
        NVRAM REPLACEMENT PROCEDURE
        NVRAM on the BCU
        Make sure that you have the SMC report (factory settings). This report comes with the
        machine.
        Output the SMC data (SP5-990-001) if possible.
        • luca72
          • Oct 2017
          • 1778
          #19
          NVRAM on the BCU
          machine.
          I don't think so...do this test
          with the main door open, activate the safety switches with a screwdriver or a piece of paper, maybe get someone to help you, then with one hand try to keep the door (the one with the lever) pushed against the drums preferably in the area of ​the cyan pcdu, and turn on the machine, and see what happens​
          "I'll be back"
          • Gabriel
            • Jun 2006
            • 139
            #20
            Check the pentagon-shaped window for all four colors. If you can see a red area, the unit was not installed
            correctly.
