black undetectable ricoh mp c3300
  • die
    • Dec 2024
    • 7
    system status
    black not detectable
    the other three toners are detectable.
    in sp mode what code do i need to change to make black detectable?
    thanks
    • 37491
    Didn't like the replies you got to yesterday's post on the same subject?
    • die
      • Dec 2024
      • 7
      no it was another problem. what is the code to activate black reading?
        • 37491
        I gave them to you yesterday but here they are again.
        Might be a couple of things:
        1. Bad RFID chip on the K cartridge
        2. Bad RFID board
        3. RFID ON/OFF:K SP 5804 192 not set correctly
        4. RFID Communication ON - K SP 5804 196 is OFF
        5. Memory for the K cartridge is corrupted
        Check the K SP settings against the other 3 colors. They all should be the same. If not, you probably have corrupted memory. That is usually the result of a corrupted chip or an After Market cartridge. Try the following:
        1. Turn SP 5804-192 OFF
        2. Cycle power
        3. Install a new Genuine Ricoh cartridge
        4. Cycle power
        5. Turn SP 5804-192 ON
        6. Cycle power
        If that does not correct the problem, I hope you have the Birth Certificate for that machine, because you are going to have to Clear Engine Memory. If you do not have the Birth Certificate, print the Non-Default page SP 5990-006 before clearing memory and use it. SP 2101 values will need to be entered and then run forced line position.
        • die
          • Dec 2024
          • 7
          changing on/off
          SP 5804 192
          black still undetectable.
          i dont think this is the code to reactivate black?
          • luca72
            • Oct 2017
            • 1780
            Originally posted by die
            changing on/off
            SP 5804 192
            Dont be unbeliver...try!
            I think so too, but!... sometimes in this crazy world of photocopiers, can happen all, in the company we use an mpc6003, and after having messed up a bit with the sp, during a personal experiment to try to set the level to the maximum, it no longer detects the black level... tomorrow I'll try to see what happens, it's free anyway... lol
            "I'll be back"
            • anothertech
              • 1770
              First thing to do is try a new black toner bottle.
