Ricoh 5503 paper jam in area C
  • briko
    • Nov 2015
    • 22
    Hi i have problem with copier ricoh 5503 i have problem with paper jam in area C i chacked everithing but nowere jam paper seen in anather post on this forum thet is problem with foto sensor but i dont know the location for this swnsor here is the post
    Originally posted by AMS
    I finally found the problem and it was an easy fix after all. There is s sensor on the side frame for the transfer separation unit. There is a small black plastic cover covering the wires. Its the photo sensor that lets the machine know the separation unit has moved from home position and that also resets the C code jam. Even Ricoh tech support did not know about that sensor. They made a note of it in case someone else has this problem. Thanks again for every ones input on this matter.
  • MIGUELMARCHENA
    • Feb 2018
    • 195
    Thank you very much for your contribution.
    Could you post a photo? Thanks
      • 37508
      Area C could be a large number of possible jams and causes. The letter codes are strictly to tell the user where to look for the jammed paper. Now what is the actual Jam Code? It will be a J followed by a 3 digit number. So what was the J code displayed when the jam first happened? Once you open a door or cycle power the code will change to J001 if the jam has not been cleared and you will have to go to the jam history to see what the original code was. The number tells us exactly which sensor and whether it was a lead edge or trail edge jam.
      • luca72
        • Oct 2017
        • 1780
        Infact, "area c" its by user
        "I'll be back"
