White Stuffs on Thick Card Ricoh mpc4502
  • Pixtech Frameworks
    • May 2020
    • 238
    Hello Everyone,
    I got this Customer Ricoh mpc4502 print comes well on bond paper, but on thick card/paper there's these white stuffs that shows around it. I don't know if there's any SP settings around to adjust it. Attached are copy of it.
  • luca72
    • Oct 2017
    • 1784
    Re: White Stuffs on Thick Card Ricoh mpc4502
    Originally posted by Pixtech Frameworks
    Hello Everyone,
    try to set in the pc driver, setting from[speed -> quality] so reducing the speed you should solve the problem, obviously I assume that the setting of the paper you have already put it on [cardboard]...while you're at it, clean the thermistors
    "I'll be back"
    • davel
      • Oct 2011
      • 1107
      What do you expect from an aging office color machine. I assume all PM parts that are due have been replaced and you have set paper weight correctly.
      • TonerMunkeh
        Professional Moron
        • 3865
        That looks like a thoroughly ruined fusing sleeve to me.
        Hit it.
          • 23009
          Please determine what media that you're using in grams per square meter. What is the gsm?
          What media type are you setting the machine to? =^..^=
          • luca72
            • Oct 2017
            • 1784
            hi, to print images so full of color, on a laser, you have to decrease the speed, using [quality setting] I always do it, even at home, to print DVD covers ... even on normal paper
            "I'll be back"
              • 37533
              The paper type and thickness are not set properly. As a result the transfer current for the PTR is too low, the fusing temperature is too low and the motor speed is too fast. Those are the thing that are automatically adjusted when you change paper thickness.
              • luca72
                • Oct 2017
                • 1784
                hi, Slim, it might not be enough, leaving aside the dvd cover speech, which I do at home, just happened to me months ago on an mpc4502 in a stationery shop, that kind of problem, customers bring photos taken with cameras, and cd covers, to be scanned and printed, and despite all the paper thickness settings, the same result came out of the Pixtech, until I changed the driver setting, from speed to quality, then he didn't call anymore
                "I'll be back"
                  • May 2020
                  • 238
                  All paper weights are set correctly, moreover all parts where replaced recently only 16k copies.
                    • May 2020
                    • 238
                    New sleeve. But prints well on plain paper.
                      • 37533
                      Where at the C4502 or in the driver?
                        • May 2020
                        • 238
                        How do I change the driver settings Luca???
                          • May 2020
                          • 238
                          In the driver.
                            • 23009
                            If you don't know the media gsm, how do you know if the media type is set correctly ... or even machine specifications?
                              • May 2020
                              • 238
                              All paper media/types are set correctly.
