IMC2000 no ADF
  • GeorgeBest
    • Jul 2009
    • 516
    IMC2000 no ADF
    Hi,
    Got an IMC2000 delivered with an coin device on it.
    Disabled the coin unit and removed it.
    Pre installed this machine but I can't get the ADF to work. it seems that the machine thinks its not there.
    An adjustment that I missed ??
    Can't get it work , ,
    someone a clue here?
    Thanks in advance
  • mikadonovan
    • May 2008
    • 2931
    Re: IMC2000 no ADF
    Don't know for sure, but it might have an Optional Counter Interface Unit Type M12 (B870-21) that would have to be unplugged/removed.
    NEVER ASSUME ANYTHING
    • luca72
      • Oct 2017
      • 1677
      Re: IMC2000 no ADF
      Originally posted by GeorgeBest
      Hi,
      Thanks in advance
      that is, if I understand correctly, if you put a sheet in the rdf, the machine does not "beep"? in sp mode, does it give you a chance to test? freerun, etc? .... Is it possible that the black plastic flag of the sensor placed between one hinge and the other is unhooked / broken? or maybe there's scotch tape, usually put on for transport, to avoid breaking it, you told me they just delivered it to you
      "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
        • 36796
        Re: IMC2000 no ADF
        Do you know who installed the "coin device?" If so have you contacted them. Many coin operation setups disable the ADF if present. If you cannot contact the person who did the setup, get out the Point to Point and check all connection associated with the ADF.
        • luca72
          • Oct 2017
          • 1677
          Re: IMC2000 no ADF
          I don't have much experience with coin-operated meters, my boss, as he knows them, tries to avoid them, we had some time ago (cartadis t11) on some mp2000, then we discarded them .... they gave more tickets than machines ... (LOL) ... our technical policy is "we are interested in the printing cost of the rental of the machine body .. any other option, accessory, or finisher, or other ... over time it will become a ball's breaker"
          I didn't know they had an option to handle rdfs.
          if so, I'd hear the ricoh, to get the information to "re-bridge" everything.
            • 36796
            Re: IMC2000 no ADF
            Originally posted by luca72
            I don't have much experience with coin-operated meters, my boss, as he knows them, tries to avoid them, we had some time ago (cartadis t11) on some mp2000, then we discarded them .... they gave more tickets than machines ... (LOL) ... I didn't know they had an option to handle rdfs.
            I do know coin operation or in the past did. When I first started we were full line dealer for Olivetti. The Olivetti Copia II and III were also available in coin operated models call Coinfax. We had them in all the county libraries and a couple of high schools. There was also a national company that did nothing but coin-ops and use the Coinfax machines. The had them in many of the drug and discount stores and some super markets.
            When non Xerox plain paper started coming, the company I worked for had me design coin op conversions for the RBC I and RBC II. For the RBC I it combined with the 1000 sheet auxiliary feed tray I had designed.
            • luca72
              • Oct 2017
              • 1677
              Re: IMC2000 no ADF
              we had them in some school, which had expressly requested them ... but now I see that the usb ones with the nfc are "in fashion", which cost relatively little, and have no mechanical parts, the receiver gets stuck, or in the rdf, or in the plastics inside the machine body ... the problem is the proprietary software that costs, I seem to have read that there was even talk of subscriptions (?) honestly I don't know much about it, but or just given a quick look out of curiosity, the company doesn't care for this type of product for now
              • GeorgeBest
                • Jul 2009
                • 516
                Re: IMC2000 no ADF
                there was an connector that was disconnected. (probably to disable the ADF)
                Hi,
                Thanks in advance
                • mikadonovan
                  • May 2008
                  • 2931
                  Re: IMC2000 no ADF
                  Spot on.
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Re: IMC2000 no ADF
                    Hi,
                    Thanks in advance
                    Hi.
                    What happens when you open the ADF cover? - does the machine complain?
                    I second the comment on the shark fin sensor flag, that will make the machine disable the df thinking it is not properly closed onto the copy glass.
                    Press the GREEN button!!
                    • oldschool
                      • Mar 2007
                      • 245
                      Re: IMC2000 no ADF
                      When you say you disabled the coin unit, did you disable it in the SP 5113 service mode? An issue with Ricoh models, The service mode for default optional counter type has two options similarly named. Option 4 coin rack and option 6 coin rack recommended. Option 6 disables the duplex and the ADF. Ricoh doesn't really have a way to deal with a double sided copy if funds run out part way. I assume this is the thinking behind the coin rack recommended setting. This may not have any bearing on your issue but when I hear coin vending and the ADF is not working, It makes me think of those settings.
                      Jamex Tech Support: Saving the world one phone call at a time.
