ricoh mp2000
  • issambass
    • Dec 2019
    • 31
    ricoh mp2000
    hi gays
    i have a problem just in the back side of first page printed with black band
  • 8T2
    • Aug 2015
    • 257
    Re: ricoh mp2000
    Enable transfer roller cleaning...forget the SP but it's the last option under Drum SP2
    Sent from my WAS-LX1 using Tapatalk
    • anothertech
      • 1771
      Re: ricoh mp2000
      It's probably time for a new PCDU.
      • KeviM
        • Oct 2019
        • 324
        Re: ricoh mp2000
        Agreed. That mark on the back of the page (most of the time the first page) is signs that your PCU needs to be changed. You could try to change just the developer if you don't have an entire unit.
        Also change and change your Paper Transfer Roller.
        All the best
          • 37532
          Re: ricoh mp2000
          It may be necessary to replace the transfer roller then turn on cleaning to prevent a future problem.
          • rthonpm
            • Aug 2007
            • 2859
            Re: ricoh mp2000
            Agreed: if the transfer roller is that bad already, enabling cleaning now is pretty much useless.
            A full PCU PM and transfer replacement should get the machine running smoothly again.
            • luca72
              • Oct 2017
              • 1784
              Re: ricoh mp2000
              Originally posted by issambass
              [ATTACH=CONFIG]50776[/ATTACH]
              hi gays
              to solve that problem, on that series, you can start minimum-minimum with replace the developer, and cleaning the pcdu, and then go to rebuild or replace the pcdu and the transfer roller, it all depends on how many prints the consumables have.
              p.s. I have tried the speech of the automatic cleaning of the roller on a dozen machines, for two years now, and unfortunately I have not noticed any benefit.
              "I'll be back"
              • Gift
                • Mar 2011
                • 2459
                Re: ricoh mp2000
                nice phone^^
                I also think the PCU PM parts are probable too old so theres always a light toner background on the drum messing around with the transfer roller. Drum ground might be bad in rare cases...
                • Maged_elagamy
                  • Mar 2021
                  • 42
                  Re: ricoh mp2000
                  well it's obvious the PCU needs to be replaced or at least the developer
                  but if this fault appeared after replacing toner and i beleive u used a low level compatible toner and the developer is not dead
                  u can try to empty the toner and replace it with good one , then empty the developer tank from the old toner and the easiest way :
                  remove the toner hopper and keep printing almost black pages until it's empty
                  then put the new toner and it will work ISA
                    • 37532
                    Re: ricoh mp2000
                    Why not save unnecessary cost and just replace the transfer roller. That has always worked for me.
                    • Maged_elagamy
                      • Mar 2021
                      • 42
                      Re: ricoh mp2000
                      well it never worked with me when the customer uses shitty toner
                      and i always have to replace toner and in some cases the developer too
                      • luca72
                        • Oct 2017
                        • 1784
                        Re: ricoh mp2000
                        Originally posted by Gift
                        nice phone^^
                        right! to have mentioned the cleaning of the spike of the drum mass, often neglected
                        "I'll be back"
                        • luca72
                          • Oct 2017
                          • 1784
                          Re: ricoh mp2000
                          these copiers are all crazy .. LOL .. at first I always tried with that, but it never worked
                          "I'll be back"
                            • 37532
                            Re: ricoh mp2000
                            The dealership I worked for never gave our customers shitty toner. Genuine Ricoh toner was included with our maintenance contracts.
                            • Maged_elagamy
                              • Mar 2021
                              • 42
                              Re: ricoh mp2000
                              good for u and for the customer as well
                              but this is not the situation in many cases
