Ricoh 1035 paper jam Code: 013
  • Kosta25
    • Jun 2021
    • 10
    crab leg buffet wilmington nc
    Ricoh Aficio 1035 paper stop at this point after i cleaned used toner bottle (it was full).
  • KeviM
    • Oct 2019
    • 324
    Re: Ricoh 1035 paper jam Code: 013
    On the 1035 that normally refers to a jam at either the registration sensor or fuser/duplex sensor.
    Change those 3 sensors
    But before you do that please do a full major service. Also please check if your transfer belt unit is turning properly. That transfer belt unit should be stripped cleaned and serviced and transfer belt and blade should be changed.
    Hope that helps
    • KeviM
      • Oct 2019
      • 324
      Also check if your registration roller is turning and if your registration clutch is working. Could be a faulty clutch.
      • Maged_elagamy
        • Mar 2021
        • 42
        agree
        it's 80% regestration sensor need to be cleaned
        and if the sensor is ok try to check the regestration rollers it may be the clutch
        • 8T2
          • Aug 2015
          • 257
          Over and above what has already been suggested I think being as old as a 1035 is there's a chance your registration bushes broke so would check them out too if I was scratching around there
          Sent from my WAS-LX1 using Tapatalk
          • luca72
            • Oct 2017
            • 1780
            doesn't seem to look good, starts with cleaning all sensors ... blow air (carefully) + wet cotton fiock
            "I'll be back"
              • 37508
              I am seeing a lot of waste toner on the ends of the drum to include latent image of the previous page copied. I am also seeing toner that has dropped down onto the registration roller and other areas below the drum. Given that J013 is a late registration sensor jam, i.e. the lead edge is either late or not detected at all, I would say that the registration sensor is also coated with toner. Cleaning the sensor with a soft lint free cotton clothe moistened with water only should take care of the problem for a while but until you correct whatever is causing the toner dropping, it will be back.
              • Kosta25
                • Jun 2021
                • 10
                Sorry but where is located registration senzor?
                • KeviM
                  • Oct 2019
                  • 324
                  Registration sensor is directly below the registration rollers which is the rubber roller and silver roller where the paper is stopping and not going through.
                  My friend this is printer and copier repair basics , if you don't know this it makes me wonder if you know printer repairs. Please friend be careful. If you don't know what you doing you can end up causing more damage.
                  Also , what Slimslob said is absolutely right, which is why I said that the machine needs a major service
                  All the best to you
                  • luca72
                    • Oct 2017
                    • 1780
                    with this question, you made it clear that you are not a technician (nothing bad) but it is better to specify! so that the advice given to you is specific to your rank! otherwise you could worsen the situation, and possibly run risks for your safety, in the event, even if rare, of problems on high voltage, or overheated component!
                    "I'll be back"
                    • GIUBOSS
                      • 1436
                      my first step for paper jams is to always start from the starting point of the paper, check the rubber rollers of the drawer if smooth or old, you could try another paper drawer, then on these old models the paper size indicated in the green wheel placed at the bottom of the drawer must match the orientation of the sheet.
                      • Kosta25
                        • Jun 2021
                        • 10
                        Solved. Registration sensor was dirty.
                        Thank you!
                        • Maged_elagamy
                          • Mar 2021
                          • 42
                          Thank you!
                          well that was unexpected
