Loading Toner RICOH MP C305 !!!
  • Maged_elagamy
    • Mar 2021
    • 42
    a RICOH MP C305 giving loading toner msg and there is no magenta color on printed paper
    well at first i supposed it's an easy task
    here what i did
    i checked the M toner cartridge and it's fine
    PCU is ok as well
    i thought it must be toner supply spiral in the hopper
    but after i reached it after some efforts i found it's not supplying toner for some reasons
    i cleaned it well and gave it a try but the problem is the same
    so i replaced the M hopper to just to be sure but the same problem is present
    finally i replaced the PCU ( and i'm sure it's fine ) but the same problem
    i suspect the Toner supplying motor of M but the toner bottle is rotating like normal
    any idea what might the problem be ?
    all help is highly appreciated
  • copier tech
    • 8172
    Re: Loading Toner RICOH MP C305 !!!
    here what i did
    PCU is ok as well
    After you replaced the magenta PCDU did the machine initially work ok?
    What firmware version is the machine on?
    • Maged_elagamy
      • Mar 2021
      • 42
      after replacing PCDU it worked fine as the new unit had sufficient toner
      but still no toner is supplied in the unit
        • 37532
        here what i did
        PCU is ok as well
        Sounds like the magenta development unit is not rotating. All three color development units are driven by the same motor and clutch. That leaves the gear train for the magenta development unit. Have fun.
        • anothertech
          • 1771
          Have you tried a new bottle of toner?
          • Maged_elagamy
            • Mar 2021
            • 42
            i've tried new unit and it didn't solve the problem
            • Maged_elagamy
              • Mar 2021
              • 42
              i didn't try new one but i checked the bottle and i'm 100% sure it's working fine
              even i've tried supplying toner manually
              my question is , if the motor rotating the bottle gives movement to the the hopper gear and spiral
              and the bottle is rotating as normal
              so why not the stupid spiral do it's function and supply toner !
                • 37532
                If the shutter in the toner bottle is clogged or otherwise not working properly then toner will not be able to get out of the bottle. Ergo anothertech's question as to if you have changed the bottle.
                  • 37532
                  Do you mean that you ordered and replaced the DRIVE UNITRUMEVELOPMENT:TRANS?
                  • copier tech
                    • 8172
                    And what about my 2nd question re firmware version?
                    This bulletin is old but maybe the cause of your issue.
                    Toner replacement alert does not clear.pdf
                    • Maged_elagamy
                      • Mar 2021
                      • 42
                      [ATTACH]50810[/ATTACH]
                      I don't know the version
                      i can check later
                      but i'm pretty sure it's a mechanical issue
                      • Maged_elagamy
                        • Mar 2021
                        • 42
                        i checked it and it's not clogged and working fine
                        the tricky thing is the bottle supplying toner to the hopper but the spiral is not supplying to the PCDU
                        so i replaced the hopper with 100% functioning spiral but still the same problem
                        • Maged_elagamy
                          • Mar 2021
                          • 42
                          of course not
                          i tried another PCDU form another machine that's working fine
                            • 37532
                            of course not
                            If you did not replace the drive unit and the problem is a broken gear in that drive unit, the developer coils in the PCDU will not be turning. If they are not turning, the toner cannot get out of the hopper coil assembly.
                            • ngocduc
                              • Feb 2023
                              • 9
                              how to know the pcdu is not work any more , please .
                              how to test it ? and i want buy the PCDU, where sale it please
                              thanks so much
