RICOH MP XX54-XX55 models toner level
  • copyaction
    • Oct 2007
    • 985
    #16
    Re: RICOH MP XX54-XX55 models toner level
    Originally posted by enricos
    I've just come back from the customer, the toner bottle is almost empty but on the display the toner icon is full (model is RICOH MP 4054).
    Checking the SPs, 3100-01 is set to 0, every other SP is on it default value.
    SP 3101-001 value is 2 (full).
    I have a doubt, does these models ever show a decreasing toner level on-display or just drop from 100% to 10% every time?
    • tonerhead
      • Sep 2009
      • 582
      #17
      The toner tubes are not chipped. Some of that is the issue. If the toner is not shaken before inserted, it may cake together and not flow into the dev unit. Eventually the dev unit will ask for toner and not get it x number of times. At this point toner jumps from nearly full to empty. The customer starts to replace toner and notices the tube is still 3/4 full, shakes it and puts it back in. Because there is no chip the machines registers this as a full tube again. Where the trouble comes in is when there is say 10-20% left in the tube, the customer shakes the tube and reinserts, the machine considers it full again. The person ordering supplies sees a full tube and a short time later it shows empty and they don't have a reserve.
      I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
      Especially when it comes to sex
      • anothertech
        • 1756
        #18
        Originally posted by dalewb74
        firmware updated?
        This was never answered, could be possible that firmware will help, I found this.
        Engine ver. 1.05:05  The remaining toner amount displayed before printing starts is 91%~100% regardless ofthe actual remaining amount, when turning the power OFF/ON or when returning from theenergy saving mode.
        • enricos
          • Mar 2019
          • 19
          #19
          Yes, 1 machine that I'm keeping an eye on is up to date (I've upgraded the firmware package 4 months ago)
          • anothertech
            • 1756
            #20
            Toner reporting.pdf
            Maybe this will help.
            • enricos
              • Mar 2019
              • 19
              #21
              [ATTACH]50893[/ATTACH]
              Thanks, I'll have a look the first time I'll be working on a b/w machine
              • enricos
                • Mar 2019
                • 19
                #22
                Hi everyone, I've found the correct sp that enables toner level reporting on MP XX55 and IM 2702 models, SP 3-903-005 set to 1 is for MP XX55 models, SP 2-903-004 to 1 is for IM 2702 models
