RICOH MP XX54-XX55 models toner level
  • enricos
    • Mar 2019
    • 19
    Hi everyone,
    I have a few copiers (for example RICOH MP5055, MP 4054) that always shows 100% toner level on the display and comunicate that level to the monitoring software as well. It happened that upgrading the firmware of a copier solved the issue but in other cases the problem persist. Any suggestions?
  • Drivee
    • Nov 2020
    • 322
    Re: RICOH MP XX54-XX55 models toner level
    They are OEM or AM?
    • enricos
      • Mar 2019
      • 19
      I don't know what that means, I think you are asking if they're originals, yes they are. Sometimes they're brand new, they work well for month then suddenly always show 100% toner and never decrease
      • luca72
        • Oct 2017
        • 1747
        Originally posted by enricos
        Hi everyone,
        you know that I did not understand the question ... you say that despite being consumed, it always remained at 100%? .. if so, I have no feedback, never happened ... at the limit it happened to me, that the "bar" did not appear, but, it was the faulty chip
        "I'll be back"
        • Drivee
          • Nov 2020
          • 322
          I dont know about Ricoh, but toner yield for Canon IR can be changed. Maybe this is cause with Ricoh as well. Yield is I think 9000, what if someone by mistake set up to 90 000 pages.
          btw
          How you see that toner need to be changed? Supplay status just drop on 0%?
          • enricos
            • Mar 2019
            • 19
            Correct, toner stays at 100% until it drop to 10%-0% when it's finished
            • enricos
              • Mar 2019
              • 19
              btw
              Yes, toner level drop to 10% or 0% when it's finished. I don't think that someone changed similar settings, we (me and my colleagues) don't even know if there are
              • Drivee
                • Nov 2020
                • 322
                OK, I see. If you have any toner which already work for 3-4000 pages, try to take out toner, shake a toner and reisntall same toner. Then, restart printer. I wonder what will happen. I am not usre how this printer measure toenr level but I think that have toner sensor, maybe is just dirty. If pritner is new, then this should not be a cause.
                Also, try to print setings of printer which work well and defective one, compare pages....
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  A few stupidities I've had to deal with on the Corona and it's toner supply have had to do with the ID sensor being dirty. I've seen two SP8400's now that have done the same thing. They won't recover from toner end as the ID sensor was absolutely covered with toner. May be worth a look if yours is being stupid too.
                  Hit it.
                    • 37365
                    Was the toner supply system properly initialized when the machine was unboxed?
                    • dalewb74
                      • Feb 2018
                      • 1126
                      firmware updated?
                      • mikadonovan
                        • May 2008
                        • 2931
                        If toner end detection has been disabled (SP 3xxx) it will show full toners all the time.
                        NEVER ASSUME ANYTHING
                          • 37365
                          SP 3100-001 to be exact. If is is set to 1 it will cause the problem. Usually used with color models when the RFID board is bad to allow operation while waiting for a new board.
                          • mikadonovan
                            • May 2008
                            • 2931
                            Or to squeeze out another day of machine use while waiting on a toner pump.
                            • enricos
                              • Mar 2019
                              • 19
                              I've just come back from the customer, the toner bottle is almost empty but on the display the toner icon is full (model is RICOH MP 4054).
                              Checking the SPs, 3100-01 is set to 0, every other SP is on it default value.
                              SP 3101-001 value is 2 (full).
                              I have a doubt, does these models ever show a decreasing toner level on-display or just drop from 100% to 10% every time?
