1224c sc555
  • ash_572
    • Oct 2008
    • 523
    1224c sc555
    cant seem to get rid of this code. comes bk after like 200 secs resting the code. i recently changed the fusing belt and while i was change the belt i accidently broke the fusing pressure lamp. so i replaced the lamp and put it all back together ans since then ive been getting this sc555. lamp i changed was a 350w according to the manuel. wen i looked at the temperature of the pressure lamp it was on 82 degrees.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    you must have changed the lamps the pressure roller lamp is 770W and the hot roller is 350W
    • ash_572
      • Oct 2008
      • 523
      actually pressure roller lamp is 350 w and the heat roller lamp is 770w. nolt the other way round.
      • iMind
        • Mar 2008
        • 1116
        Sorry, your statement is correct, did you connect the themistor switch in the middle back of the fuser this is a easy one to forget to connect.
        • ash_572
          • Oct 2008
          • 523
          yes its connected.
          • TonerMunkeh
            Professional Moron
            • 3873
            Can you try another complete fuser in it? Spare one or one robbed from another machine?
            Hit it.
            • Jomama46
              • 2900
              If its warming to 82 degrees, the stats are OK. I think it may be the PSU. But thermistors are cheaper and easier to replace and they may cause the fault too.
              sigpic
              A+; Network +; PDI+
              • ash_572
                • Oct 2008
                • 523
                cant actually get hold of another fuser unit otherwise i would have done tht. today i replaced the thermofuse and the thermister. switched the machine bak on nd sc did not appear. but bear in mind it may come back in after a few days.
                and also i noticed sumfin bout the pressure roller lamp (350w) there was a broken wire inside the lamp when i looked carefully. i put me testers on boths ends and no continuity. this was already replaced so i dont understand why its broke again. am i blowin it o summat? if it cms back in then al replace the lamp.
                • Lagonda
                  • Aug 2008
                  • 1650
                  I think you were just unlucky. Be very gentle with the lamps, the filament gets brittle with old age. Your first post sounded like you had reversed the lamps, I know I've done it!
                  • ash_572
                    • Oct 2008
                    • 523
                    the sc 555 came back in again today gonna go for a new lamp now nd see wat happens.
