SC542-02
  • imran181070
    • Aug 2016
    • 24
    [Error Code] SC542-02
    HI guys
    help is required for RICOH C5300
    already printed near to 2 millions , its suddenly SC 542-02 appears
    things done as follows
    1 checked power outlet & tried other power outlet and tested with volt meter power is ok
    2 replaced thermopile & both thermistors
    3 replaced ACCONTROL BPARD & INVERTOR BOARD
    4 replaced FUSER UNIT from working machine
    5 replaced IOB
    if any1 face this problem .thanks is small word
    thanks
    • 37447
    SC542-02 is a fusing unit error. To prevent further damage to the machine the error must be reset through the Service Program.
    Turn the main switch Off then On
    Execute SP5-810-1
    If the error returns then the cause has not been corrected.
    SC542-02 rear thermostat open.
    • Tony in Oz
      • Dec 2021
      • 13
      the -02 codes require a hard reset by pico fuse, you'll need to find & replace the pico fuse, usually near the blue fuser to m/c connector, and do 5-810-02 reset on it
      • imran181070
        • Aug 2016
        • 24
        Execute SP5-810-1
        THANKS SIR
        we already replaced fuser unit complete
        • imran181070
          • Aug 2016
          • 24
          appreciate your response .did not found pico fuse in PC or in CD (circuit Diagram) connector for fusing unit has blue & black connector both removed and checked all harness with test meter , could help for PICO FUSE for location and explain for HARD RESET
          • Steve Tech
            • May 2024
            • 30
            Not worked on the C5300 personally but with Ricoh the reset fuse comes with new fusing sleeve or unit, you can't buy it as a separate item from Ricoh. You could try Google, you may be lucky and find one that works.
              • 37447
              Originally posted by imran181070
              THANKS SIR
              But if you did not clear the error with the correct Service Program procedure the error will still be stored in memory. As for the pico fuse, they only come with a new fusing assembly from Ricoh, often taped to the bottom of the inside of the box. The only thing you will find is an empty connector where it needs to be plugged in. Also with some models one of the jam doors needs to be open when the SP is executed.
              • imran181070
                • Aug 2016
                • 24
                appreciate sir kind response
                do you mean the FUSE with wire in MP and IM models fuser sleeve contain fuser in box ?
                  • 37447
                  Yes. The fuse is not needed when replacing a sleeve as part of a scheduled maintenance service and since I had to make very few repairs that required one I had quite a collection in my tool bag.
                  • imran181070
                    • Aug 2016
                    • 24
                    thanks for information also could you explain what kind of fuse is that you use & where to put , due this model has male & female connectors not like mp or im series , it ll be more helpful and appreciated that might share this info how did you that with sample pic
                    regards
                    • davel
                      • Oct 2011
                      • 1099
                      I don’t think this range of machines has a pico fuse.
                      • copier tech
                        • 8138
                        HI guys
                        5 replaced IOB
                        thanks
                        Check the thermopiles with a multi meter.
                        SC 542-02.pdf
                        • dalewb74
                          • Feb 2018
                          • 1143
                          are you referring to a pro c5300? i agree with slim and the others, check the fuse.
