New MP4000 Dev Unit
  • tcs04
    FORMER Techie
    • 1183
    #76
    I posted this on another thread earlier, may shed some light on the situation (?)
    I have noted this problem on about 40% of MP4000 / 5000 machines (so far) as as a result my company requested a number of kits From Ricoh. They initially refused our requests on the grounds that the problems were not severe enough to require modified units (!). Suffice to say, I now have a number of modified Dev Units ready to fit.
    I spoke to a Ricoh Helpdesk Engineer (One of the good ones, known him for years and trust what he says) face to face on Thursday and this is the latest as I recall.
    This is the same problem, to a much greater degree, that we have all experienced in the past on AF1035, AF2065, AF3045, MP4500 and now on MP4000 / 5000.
    The problem has become worse as the amount of wax in the toner has increased through the model series with the objective of reducing adhesion to fuser rollers and lowering energy consumption (Lower fuser temp).
    We (in the UK) can, if we shout loud enough, obtain modified Dev Units and a bag of Dev (NOT modified) from RUK. Earlier inquiries may have received complete PCDU kits.
    The Dev units suppied have a similar doctor gap and a new coating (Unspecified) on the mag roller.
    THIS IS NOT THE "FINAL" FIX. However "Trusted (ex Ricoh) engineers have fitted the new units and report that they work"....... (until the coating wears off ????)
    Ricoh are expecting to provide a "New" toner "in June" (containing less wax?) "which will be a final solution to the problem".
    I assume (Didn't ask) that there will be developer incorporating this new toner supplied at the same time.
    I did make the point that this problem had become worse over time (agreed) and that if fuser cleaning efficiency had been an issue, it should have been cured by the fusing web now fitted (agreed).
    One problem we will all face is that unless we are supplied with both kits and toner for ALL mp4000 / 5000 machines, there will be a mix up of toner or dev at some point, especially at customers who have multiple units.
    I suppose we should look on the bright side in so much as this will keep our work levels up during the credit crunch!
    I have tried the Drum earth solution even to extent of adding an extra contact (similar to AF2090) with liitle change in the outcome.
    I had also considered the AF2045 dev / toner approach and would be interested to know if if works, I suspect it will in the short term at least. Does the AF2045 toner bottle fit this machine??
    (Thanks to aabarnes1 in this thread re the AF2045 dev, will now try this on a tame customer. Makes sense as the AF2045 dev is probably coarser and the toner contains less wax? Are you using AF2045 toner???)
    • stephend
      Senior Technician
      • 306
      #77
      Hi Lagonda,
      part number is D0092301. Modify voltages like for a Ricoh 3500/4500.
      My opinion is clear: this new combination of toner/dev used in 4500 & now 4000/5000 is a bad one....but those are the efforts made to be "green" + because of the market & competition....latest models are not tested enough in different environments....they just launch them as soon as possible to be one step aheat competition
      • Shadow1
        • Sep 2008
        • 1642
        #78
        ...that's not a good thing if they end of the path is the company's grave. Ricoh has totally destroyed their reputation for this speed/niche machine. I bleed Ricoh Red right to the core, but I have to tell anybody thinking about getting one how bad they suck. Good encouragement to go color, but here's an interesting question: If the customer has to have a 40ppm b/w machine would you give them a MP4000 and let them think Ricoh machines are all that bad or should you be honest and tell them this particular model is a dog but the >31 and 51< machines are great even if it means they buy from a competitor???
        NOTE TO Ricoh Corporate: It's pathetic you've allowed the engineers to drag their feet through 2 generations of machine and still not have a fix (if it fixes it) in widespread release and make us ask questions like this.
        NOTE TO Engineers: The problem is the toner. Always has been. B079 supplies will work fine if you modify the machine to accept the toner.
        73 DE W5SSJ
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          #79
          I completely agree with this statement and have stated so on the board numerous times. Almost two and a half years for a solution? That is more than unacceptable. Technicians fixing machines with old supplies; repeated bulletins that don't resolve the issue; having dealers continue to throw developer, dev units and drum shafts to no end. It all seems like they really don't care about this segment of machine, how poorly it runs or how much they're affecting dealers and their bottom line. We've lost customers because of the last two models of machine!!! Not just one or two either. Several. And we're not that big of a dealership. We've tried to eliminate the sale of these as much as possible, but it's really hard to go against competitors with a smaller or larger segment machine. It ends up being over worked or over priced. Not that the salespersons really give two shakes about the service side (until they want to sell new equipment). It's really a no win situation for everyone. It's been seriously looked at to go with a second brand to sell just this segment. That doesn't end good for Ricoh, even if they did buy out Ikon.
          Sorry for the soapboxing, needed to get a little rant out.
          • tcs04
            FORMER Techie
            • 1183
            #80
            Hi Lagonda,
            I was told by Ricoh Tech that the main source of the problem was the amount of wax added in greater amounts to each "upgrade" of the range (AF1045 onwards).
            If we assume this wax is the material which accumulates on the mag roller, it is possible that heat would contribute to the problem.
            The main difference between the dev units, aside from the coating on the mag roller (it looks the same) seems to be a change to the filter on the new unit which is MUCH larger and now extends the full width of the roller, I imagine his would have a considerable effect on airflow and therefore cooling of the unit which may help maintain a temperature below the melting point of the wax.
            I would not be suprised if the "new" toner is simply AF2045 toner (Less wax?) in MP4000 bottles. If the combination of less wax and lower temperature was the cause of the problem it may be that this new setup WILL cure the fault.
            The acid test will be when the new toner arrives in June.
            Time will tell!!
            • cobiray
              • Mar 2008
              • 1199
              #81
              Anyone that's state side gotten their hands on any of the "new" toner? I've been told we have to deplete the stock of "old" toner and that Ricoh isn't taking it back. WTF?!?!? Seems like once again we're getting the shitty end of the stick from Ricoh. We are to use it on the machines not exhibiting any symptoms. Really? The ones not exhibiting symptoms? That must mean the ones that haven't been unboxed yet. I'm still having trouble finding one that doesn't do this.
              • tcs04
                FORMER Techie
                • 1183
                #82
                I expect to be supplied with some of the first toner to arrive in the UK in June and if not will go to RUK and collect some!
                Will report as soon as I get the chance to try it.
                As you say... "We are to use it on the machines not exhibiting any symptoms. Really? The ones not exhibiting symptoms? That must mean the ones that haven't been unboxed yet. I'm still having trouble finding one that doesn't do this."
                What happens if the customer has some that do and some that don't?
                • Jomama46
                  • 2900
                  #83
                  Exactly, I have only one customer with this problem and they have an MP5000. Have to go there every 10-15K. SameShxt. Down the hall they have a MP4500. Interchangable toner. Nery a peep out of it.
                  The 5000 has a new style developer, 'cause i scrubbed the mag roll so many times, it was getting smaller in diameter, (hehe), modifed the bias settings so that the copy is always on the light side, and replaced the drum bearing in the rear. Everything works for a while. I have a PCU ordered for it for the next time.
                  It is just perplexing that the supplies work in the other machine and not this one.We also have 2-3 other MP4000s and a dozen MP4500s that run great.
                  This one is the problem and it has all the classic symptoms.
                  sigpic
                  A+; Network +; PDI+
                  • tcs04
                    FORMER Techie
                    • 1183
                    #84
                    Great feedback, but I do think you should call The Dog Whisperer!!!!!!!!
                    • Shadow1
                      • Sep 2008
                      • 1642
                      #85
                      Annother NOTE TO Ricoh: This thread (and all the many others regarding this problem) should be used as a case study in what NOT to do. I've always been taught that good service is not that things never go wrong - that's not realistic - it's what you do when things do go wrong.
                      Ricoh's solution so far has been:
                      Step 1: Ignore the problem
                      Step 2: Ignore any input from the people who actually have to make these evil boxes work in the field and might have some idea what will really fix things.
                      Step 3: Issue some half-a$$ed patches that don't fix the problem and cause other problems.
                      Step 4: Ignore the problem some more.
                      Step 5: Repeat Step 2
                      Step 6: Introduce a new machine with the same problem
                      Step 7: Repeat Steps 1-6 for both series machines.
                      Step 8: Refuse to acknowledge this is a widespread and serious problem
                      Step 9: Issue a fix that finally has a hope of working and drag your feet getting it to the field.
                      Step 10: Leave plenty of the stuff causing the problem out there to haunt us some more.
                      Have I missed anything?
                      Sorry I couldn't make this a 12 step program, 'cuz somebody's drunk.
                      73 DE W5SSJ
                      • tcs04
                        FORMER Techie
                        • 1183
                        #86
                        MODIFIED TONER
                        GOOD NEWS (Yeah..... Right!!)
                        I've just received an email detailing the "FINAL SOLUTION" to the background problem!!!! (Yeah..... Right!!)
                        (See attached)
                        Ricoh UK now say the new toner will fix the problem on its own and that the modified units are no longer available
                        I'll believe it when I see it!!!!
                        • Jomama46
                          • 2900
                          #87
                          OMG. Is that the way you spell money?
                          sigpic
                          A+; Network +; PDI+
                          • tcs04
                            FORMER Techie
                            • 1183
                            #88
                            BLACK GOLD!!!!!!!
                            • Jomama46
                              • 2900
                              #89
                              Thanks for posting that.
                              sigpic
                              A+; Network +; PDI+
                              • cobiray
                                • Mar 2008
                                • 1199
                                #90
                                I love the symptom; "Dirty background image sometimes appears." Sometimes? As in only when in use? Only when unboxed? Who says these guys don't have a sense of humor?
