New MP4000 Dev Unit
  • Noj7373
    • 20
    New MP4000 Dev Unit
    Has anyone installed one of the new MP4000 Dev Units out in the field? And how has it help if at all the build up on the mag roll? I installed one about 3 weeks ago and checked on it today and looks like the CQ is getting light already. But they are closer to the max volume limit for this machine, about 20K in 3 weeks.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      Meh. I don't think it is going to be a final solution, from what I've heard. I've had the newest ones (the ones with the addition of two more smaller filters on the end) and haven't had the scumming as bad or as often, but it still comes back. I'm so sick of these machines.
      • iMind
        • Mar 2008
        • 1116
        False alarm, the other toner cap was left in the toner hopper.
        • Guvnah
          Toner Monkey
          • Mar 2009
          • 19
          Dev unit 335
          I replaced the dev unit in a Lanier LD335 several months ago. (sorry don't recall Ricoh name for it- it's the precursor to the MP4000 with the same toner/dev)
          I have also replaced the PCU assembly.
          Nothing improved the machine. It still coats the mag roll and goes light and packs the waste toner path like clockwork. It needs the PCU cleaned out about every 20-25K and needs new dev about every 60-80K.
          These new machines are fun stuff.
          *EDIT*
          Oops- didn't realize there was a new unit available. I'm going to have to try one out.
          • Llama God
            • Mar 2009
            • 1353
            I haven't had one bounce on me as yet, and it's not like there haven't been problems before the new dev units were fitted, but confidence in this model has been shot to bits. I'm waiting for the calls...
            • Lagonda
              • Aug 2008
              • 1649
              MP 4000 Dev unit
              Anyone got a part number for this new dev unit? And what changes have they made?
              • unisys12
                • 490
                Some of us are experimenting with Brillianize on the mag rollers. After cleaning them up of course. Since how team has heard about it, which was only a few weeks ago, we have done several but have not been able to check back in on any of them as of yet.
                One tech went on a called for a shadowing condition and after cleaning the mag roller with alcohol, followed by a good wipe down with Brillianize, plus following the adjustments outline in the TSB #007 for the D011 family and it worked great. This machine would only run about two weeks until it would start shadowing again. So far it's been just about that, two weeks, so we'll have to wait and see.
                But, one thing I can say is that we have not had any problems from using the Brillianize on the mag rollers. Now if I could just get the guys to use it for other things...
                sigpic
                The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
                • unisys12
                  • 490
                  TSB#34 my friend
                  sigpic
                  • Lagonda
                    • Aug 2008
                    • 1649
                    Originally posted by unisys12
                    TSB#34 my friend
                    It may be TSB 34 in your neck of the woods but out here it will be RTB and 6 digits. Have just searched thru Ricoh Oz's Tech site and have found no reference to an upgraded dev unit, so is there a chance you could be a little more forthcoming with some info?
                    Also what the hell is Brillianize? Some sort of South American hair oil?
                    • unisys12
                      • 490
                      Hair oil... LOL!
                      No, No... sorry, Brillianize #1 Rated Plastic Cleaner and Plastic Polish
                      As for the part number of the new dev unit... D009-2301. Hope that helps.
                      sigpic
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Yep, that helps lots. I've just ordered one and I'll see what turns up,
                        As for Brillianize I'll have a hunt around to see if there is an Oz vertion of it.
                        By the way Unisys, since its 1.30 PM Thursday arvo here it must be about 10.30 PM Wednesday night where you are. What are you still doing thinking about photocopiers that late at night for? Have you considered that you might need help? Try getting out more often and meet some normal people! Cheers, Phil.
                        • unisys12
                          • 490
                          Normal people?
                          sigpic
                          • Guvnah
                            Toner Monkey
                            • Mar 2009
                            • 19
                            MP3500/4500
                            There is also an update for the older model 35/45 if anyone has been fighting those as well (like me)
                            Lanier LD335/445
                            Ricoh MP3500/4500
                            tsb 14
                            New dev unit B2133011
                            new dev sleeve only (mag roll assembly) B0823101
                            • cobiray
                              • Mar 2008
                              • 1199
                              Have you had any success replacing just the mags on the 3500/4500? I have a few of these that are just pukers, even after having the new mags put in. Also been doing everything else recommended (vacuuming the waste section, bias adjustments and paper between the units when adjusting dev). I've even been lowering the fuser temps and lowering the energy save and auto off timer settings. Grrrrrrrr.
