P 502, drum not set
  • The_man
    • Jan 2016
    • 40
    [Error Code] P 502, drum not set
    Firstly, suspected pcdu, swapped with working pcdu, still the same. Tried pcdu reset.
    Fitted 2 new connetors, as tend to bend when forced.
    Suspect bicu now, unless anyone had this.
  • luca72
    • Oct 2017
    • 1792
    Re: P 502, drum not set
    it is not to be excluded! but it could be the psu that does not provide the correct outputs, you can do a voltage and continuity test between CN442 (ID_CHIP PCDU) and CN100 (SCB) so you can also see if there is a mechanical problem of the contacts pcdu> mc
    also check CN214 and CN215 on psu to verify the presence of voltage outputs (see attachment)
    "I'll be back"
    • The_man
      • Jan 2016
      • 40
      hi thanks for reply have fitted egb, ctrl and psu still the same, looking like a service swap out.
