Sc860, sc819
  • babu
    • Apr 2018
    • 19
    Sc860, sc819
    I have ricoh mp4000B, the machine print half page and half page blank, and when the copying start the machine is shows memory full, and show sc860, sometimes sc819, sometime sc865, i cannot format hdd, and Can't memory clear, when try to format or memory clear the machine shows error!!!!!!
    What can i do??????
  • copier tech
    • 8221
    Re: Sc860, sc819
    What can i do??????
    Sounds like the HDD has failed try replacing it.
    • babu
      • Apr 2018
      • 19
      Re: Sc860, sc819
      I replaced hdd, but the machine showed same error message
        • 37628
        Re: Sc860, sc819
        A MP 4000B does not have a HDD unless it has been added with either the HDD Option or one of the Printer Options.
        As for the SC819, it could be a controller software error. Try updating/reloading all the firmware. Otherwise you may have a bad controller board or possibly bad ram on the controller.
        If you have tried to install a Printer/Scanner SD card or a PostScript SD card without increasing the memory and/or adding the HDD, that is your problem
        • bob marley
          • Jan 2012
          • 1339
          Re: Sc860, sc819
          Try to initilize the HDD with sp 5832-001
          Live for yourself and you will live in vain. Live for others, and you will live again
          • luca72
            • Oct 2017
            • 1792
            Re: Sc860, sc819
            try to replace sata cable, may be broken/bad
            "I'll be back"
            • Zaxxon
              • 608
              Re: Sc860, sc819
              What can i do??????
              Please start you post with brand, model, problem.
              • Gift
                • Mar 2011
                • 2459
                Re: Sc860, sc819
                What happen if you test the machine without HDD connected?
                • babu
                  • Apr 2018
                  • 19
                  Re: Sc860, sc819
                  When hdd disconnected the machine do not run, show error code sc819
                  • sandmanmac
                    • 3990
                    Re: Sc860, sc819
                    SC 860 HDD startup error - replace Hard Drive
                    SC 860 HDD startup error - format with SP5-832-001
                    SC 865 HDD access error - replace Hard Drive
                    SC 865 HDD access error - format with SP5-832-001
                    SC 819 Fatal kernel error - no memory with SP5-985 turned ON, install memory turn SP5-985 to off and remove memory
                    SC 819 Fatal Kernel error - update fw WebUapl 1.10 Network DocBox 1.07M Web Support 1.53
                    SC 819 Fatal Kernel error - with '7061 6765 6f75 743a 20' appearing after code, add 256Mb Memory
                    SC 819 Fatal Kernel error - turn off NIB SP 5-985-1 to 0 if a 'B' model with no scanner or printer option
                    SC 819 Fatal Kernel error when HDD removed - Turn off on-board NIC SP 5985-1 to a 0
                    SC 819 Fatal Kernel error - replace controller
                    SC 819 Fatal kernel error - set machine type with Plug & Play use SP5-907
                    SC 819 Fatal Kernel error - with Java+PScript installed you need 512K memory
                    SC 819 Fatal kernel error - replace PostScript SD card
                    SC 819 Fatal kernel error - replace HDD
                    SC 819 Fatal Kernel error - update system fw to 1.14 or higher
                    • babu
                      • Apr 2018
                      • 19
                      Re: Sc860, sc819
                      when start copy the machine showed ....
                      .jpg
                        • 37628
                        Re: Sc860, sc819
                        If all you are doing is coping, you either have a bad BICU, bad Controller, a bad 256K DIMM on the controller or Job 101 has consumed all available memory.
                        • Gift
                          • Mar 2011
                          • 2459
                          Re: Sc860, sc819
                          Since it shows a change of behavior after removing the HDD (SC819 - there's a few SP tips listed @sandmanmac's posting, like disable the NIC) I'd say it's something controller-related - perhaps the RAM dimm, the controller itself or a bad connection. Usually it's hard to believe that the HDD wasn't the culprit, I hope the "new" one was really OK.
                          • MIKON
                            • Jul 2015
                            • 191
                            Re: Sc860, sc819
                            Try cleaning dimm and connector with contact cleaner
                            • DRichard
                              • May 2008
                              • 482
                              Re: Sc860, sc819
                              Second that...I would disconnect the HDD, pull the memory card and maybe even the NVRAM. Remove ANY and ALL devices then try to restart it. See if anything changes. It won't be fully functional, but you just want to see if it can pass POST and come to standby.
                              "Enjoy every sandwich."
                              -- Warren Zevon
