Ricoh MP2851 Poor print quality
  • darkravenz
    • Oct 2019
    • 3
    as i googling for a solution, i found about one solution that had a positive feedback which is "Memory clear the printer app and ACC it. That should sort it out.",
    and may i know how to perform that? and what is ACC?
    Last edited by darkravenz; 12-06-2021, 05:37 AM. Reason: remove Italic style for last sentence
  • 8T2
    • Aug 2015
    • 257
    Re: Ricoh MP2851 Poor print quality
    Ok luckily I'm first and in a good mood because I haven't started work yet.
    Since you had to google and don't know what it is or how to do it I assume you are an end user and not a trained tech.
    Please please please don't memory clear anything I beg you?
    If you could describe the issue or better yet supply a sample most of us would be happy to try and assist you.
    2851 is an old machine, chances are it's due for some parts and a memory clear would be like factory resetting your smart phone because the screen is cracked.
    Sent from my SM-A305F using Tapatalk
      • 37488
      I am in complete agreement with 8T2. A memory clear will in no way shape or form help with a print quality problem.
      Common cause of bad quality are PCDU needs to be rebuilt, fusing unit needs to be rebuilt, toner scattering and use of after market supplies. If it is only when sending print jobs in could even be a setting in your software or the print driver. You are not using the WMI printer port by chance or Microsoft's Class driver. Both of those are major sources of problems.
      • darkravenz
        • Oct 2019
        • 3
        Thank you for the answer. I'm now clearly understand .
        • Debs1964
          • Oct 2010
          • 1693
          ACC is auto colour calibration, the MP2851 is a black & white device and does not have ACC
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • anothertech
            • 1769
            First thing to do, young Jedi, is to clean the slit glass. Then if you are up to it, clean the optics. Good Luck and may the force be with you.
            • Gift
              • Mar 2011
              • 2459
              5 Minutes Later........:
                • 37488
                [ATTACH=CONFIG]51307[/ATTACH]
                A toner bomb. I had a customer do that once. they were changing the toner bottle and decided to shake it after removing the screw on cap.
                  Yup had that happen several times but never the same place twice.
                  • Gift
                    • Mar 2011
                    • 2459
                    ...except schools
                      ...except schools
                      No I personally trained keyop's and teachers on everything from loading paper/toner to finding/clearing jams.
                      The hardest part was teaching them simple/duplex jobs using light cardstock
                      And storing address book entries.
                      It took 1.5hrs ( unless they were boxes of rocks. )
                      I kept records that proved the little extra time spent at the gitgo saved a lot of stupid calls.
                      I also put a bottle of IPA and a few blue roll towels w/ pictures to show symptoms and the fix for lines on copies.
                      Every three months I'd go out for a refresher course if needed.
                      The keyops really grabbed the reins and rode that pony. A few schools even bought a 3m Toner Vac to keep them clean.
                      It was great being a Service Manager!
                      • Gift
                        • Mar 2011
                        • 2459
                        Guess we should have invest more time in user training but on the other hand the customers person in charge need to assign some people to talk with. That was usually the janitor - in most cases running some dude around with some sort of "I don't give a shit" attitude
                        Most user errors I recall was damaged drums/hot rollers thank's to the use of special tools during jam removals (scissors, envelope openers..) or OHP foils not suitable for high temperature.
                          • 37488
                          With most of the schools I had it was the IT person. When he called with a problem we knew there was a machine problem and not an operator error.
                          • Gift
                            • Mar 2011
                            • 2459
                            That's nice having somebody competent to talk to - in most of our schools the IT guy and janitor was kind of the same person
                            I admit this is my experience up to around 2010, nowadays schools use way more IT/mediastuff.
