We got an MPC2504ex from a wholesaler and it will not print documents from a computer or the usb/sd slots. It will print reports from printer user tools. It has Paas installed. I tried uninstalling it following the instructions in bulletin# RD0BL017a but it still won't print. When I ran SP5760-024 to remove PaaS it failed. I swapped the controller and SP5760(that is the SP that has the PaaS settings) disappeared but it still won't print. The data in light does not flash and it does not show any print jobs in the que.
I have checked SP5985 and it is set to 1.
I have cleared the printer application in SP5801-008.
There are no access control restrictions.
There are no port restrictions. I checked in telnet.
There are no user codes or key counters.
Is there anything else I can do or check?
