Quick one - Ricoh usage count
  • dagoof
    Still learning...
    • 220
    Hoping someone can help verify this count, as I'm unfamiliar with Ricoh.
    So is total usage currently 4.6m?
    I'm unsure what the -26 figure refers to:
    • 37542
    Re: Quick one - Ricoh usage count
    Try actually going into SP mode and check there. The printed information is truncated but the complete description should be shown in SP mode.
    • dagoof
      Still learning...
      • 220
      Thanks Slim, I have zero knowledge about Ricoh's though, just helping to move the machine along!
        • 37542
        If you do not have a service manual there is a forum for requesting one. https://www.copytechnet.com/forums/s...nual-requests/
          • 23009
          If I were to guess ... I'd suspect that A3 is set to single count, and your enduser is running a very high volume of A3 color. For the sake of maintenance, the machine still tracks maintenance counts with A4 sized images. And on some machines, color images count as 4 counts, so physical count of 4.6M A3 counts, the maintenance count could be as much as 8x higher (2x for A4 counts, 4x for color).
          What model did you say this is? =^..^=
          • Gift
            • Mar 2011
            • 2459
            -26 is propbably some dot/or coverage count
