Starting up the extended feature ricoh mpc3003
  • Pixtech Frameworks
    • May 2020
    • 238
    Good Day,
    A customer Ricoh Mpc3003 which show STARTING UP THE EXTENDED FEATURE forever before showing home screen. Is there anyway to permanently disable it to boot quickly??
    • 37379
    Re: Starting up the extended feature ricoh mpc3003
    Originally posted by Pixtech Frameworks
    Good Day,
    Remove the extended feature and disable JAVA.
      • May 2020
      • 238
      I have tried it, not work, although it's not showing Java screen anymore, but "please wait" its taking forever.
        • 37379
        I have tried it, not work.
        How did you "try"? Using SP mode only works when you do not have any apps enabled.
        If you have3 any apps enabled you have to do the following first:
        1. Enter User Tools from the control panel
        2. If an app is set as the default function you need to change that first and may need to reboot
        3. Once you can get into Extended Features in User Tools you need to close and then remove all apps. Follow the onscreen directions. If the app was originally installed from a SD card you will need that card to remove.
        • copier tech
          • 8131
          Good Day,
          If you have uninstalled any software from extended features try setting SP5730 (disable JAVA at start up) & format the HDD
          • anothertech
            • 1762
            Yes SP5730 from 1 to 0. I do it on every machine I see that's not using Java apps.
              • May 2020
              • 238
              I have uninstalled java from extended features and SP 5730, 5834 and still showing please wait forever.
              • copier tech
                • 8131
                And did you format the HDD ?
                • sandmanmac
                  • 3979
                  This....and also there's no indication that you've done as Tim suggested, and make sure that there is a default boot option selected in the screen features like "Home" or "Copier", for example.
                  I've come across several machines in the past that have somehow had the preferred boot function de-selected and the result was like yours - maybe 5 - 6 minutes to arrive at the home / copy screen
                    • May 2020
                    • 238
                    I've done the above mentioned including HDD format, I swapped HDD, still not booting to home screen immediately. Just please wait for ages.
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Switch off SP5113-002.
                      Hit it.
                        • May 2020
                        • 238
                        I found the solution, USER TOOLS >>SYSTEM SETTINGS >>FUNCTION PRIORITY>>HOME.
                        Function priority wasn't set to home.
                        • anothertech
                          • 1762
                          Sandmanmac gave you the solution 3 weeks ago when he said this,
                          • sandmanmac
                            • 3979
                            Yup, and he immediately responded that he tried that without success, and now he's posting as if he's some sort of hero that discovered the solution all by himself, even after starting a brand new thread for the EXACT same thing earlier today!
                            And all of that without a single word of appreciation for the dozens of suggestions along the way as far as I can see
                              • May 2020
                              • 238
                              I probably didn't read through because so many suggestions where coming in. Pardon me if I didn't appreciate anyone who had variously contributed to the success, am indeed grateful for all. Thank you
