Ricoh IM C6000 printing error!
  • hoanganh836618
    • May 2024
    • 14
    [Misc] Ricoh IM C6000 printing error!
    someone help me!
    my machine doesn't print what i want but prints strange characters
    i looked in Printer features to check but there are no tabs like PCL menu... as shown in the picture attached to my post...
    This gallery has 2 photos.
  • anothertech
    • 1770
    Try a different driver. That looks like you're using the PS driver, try a PCL driver.
      • 37491
      Or using PCL and the C6000 only has PostScript.
      • davel
        • Oct 2011
        • 1104
        Update firmware probably missing PCL firmware
        • Brianneoe
          • May 2015
          • 318
          you are missing a lot of things there. try a simple sp 5801-xxx. look through the list and select the printer. never do a all clear i.e.5801-001,002 or 003. lately when I have a print or scan issue that is missing something or is not acting correctly this will fix it
          • luca72
            • Oct 2017
            • 1780
            Originally posted by hoanganh836618
            someone help me!
            i cant see the photo, are too little, but check ip port in windows driver, could be switched in wsd
            "I'll be back"
            • hoanganh836618
              • May 2024
              • 14
              PCL6 driver doesn't work
              but when I installed it via RPCS driver in Japan region it worked.
              • hoanganh836618
                • May 2024
                • 14
                I used RICOH Firmware Update Tool but no change
                Is there any way I can add PCL fonts to my printer?
                • hoanganh836618
                  • May 2024
                  • 14
                  i tried but it didn't make any change.
                  • Mako
                    • Jan 2025
                    • 794
                    Isolate and print using the device specific driver in a clean install. This looks like a driver problem.
                    • davel
                      • Oct 2011
                      • 1104
                      Print out firmware versions and post here, may need to do firmware modules from SD card.
                      • anothertech
                        • 1770
                        Was the machine set up to use a Fiery at one time?
                        • hoanganh836618
                          • May 2024
                          • 14
                          i have these two pictures... can you help me
                          • luca72
                            • Oct 2017
                            • 1780
                            Try with a cross cable to connect directly to the pc, and the driver is already installed and ready, and see what happens
                            "I'll be back"
                              • 37491
                              I think what davel was really wanting is the diagnostic report from the Service Program.
                              From what you have provided it appears that the only installed print function is RPCS, something I thought Ricoh had discontinued using. PCL is not shown and therefore might not be installed. Either that or it has been deleted or is corrupted to the point of not being recognized. You may need to pay to have a Ricoh support visit to correct the problem. The other options is to buy the PS3 option and use the Postscript driver.
