mp 4054 curling on the ends
    • 37488
    #31
    Re: mp 4054 curling on the ends
    Originally posted by rthonpm
    I always recommend at least 24# paper (do the calculations for all you metric folks) for any colour machine. It's a little heavier and holds up much better especially with any degree of coverage on the page.
    Sent from my BlackBerry using Tapatalk
    I was told once by a Ricoh regional rep that when doing duplex color to use 28# to avoid image bleed through.
    • tsbservice
      Field tech
      • 8013
      #32
      They did some real/proper training 20+ years ago. Now go figure...or use CTN.
      • KeviM
        • Oct 2019
        • 324
        #33
        • digicor
          • Jul 2008
          • 1153
          #34
          Okay update, i put 24 pound paper in, all good
          after
          1)lowering temp as suggested
          2)using middle thick,plain 2 settings
          3)checking fuser and other paths for obstructions, or pinching / none was found
          I reccomend to client they try 22# instead of 24# all i had was 24#
          also they were using the cheapest paper i dont think it was a true 20#
          so for now
          FYI: 500 sheets of 24# wont fit in a 500 sheet tray.... the overflow goes into tray 4 for later use in a 4 drawer set up
