c7100ex color
  • romario
    • Jun 2020
    • 192
    [Dead] c7100ex color
    I installed the maquiba 5 days ago perfect, today the client presented this color fault, the strange thing is that I print cmyk at a% of 100, 50, 25 and they all work out, now I print the design arts and yellow fails me, now change cylinder, development unit, charge roller, and follow the failure, can someone help me... IMG-20211221-WA0123.jpgIMG-20211221-WA0125.jpg(correct print is green)
    thanks
    Re: c7100ex color
    Originally posted by romario
    I installed the maquiba 5 days ago perfect, today the client presented this color fault, the strange thing is that I print cmyk at a% of 100, 50, 25 and they all work out, now I print the design arts and yellow fails me, now change cylinder, development unit, charge roller, and follow the failure, can someone help me... [ATTACH=CONFIG]51206[/ATTACH][ATTACH=CONFIG]51207[/ATTACH](correct print is green)
    What file type?
    What gsm of media opposed to machine settings?
    So many important info bits left out.
    • romario
      • Jun 2020
      • 192
      Re: c7100ex color
      What file type?
      all types of paper, from 52 grams to 300 grams
      thanks
      • davel
        • Oct 2011
        • 1104
        Re: c7100ex color
        Have you done Auto Colour Calibration?
          • 37487
          Re: c7100ex color
          But do the machine settings match the specific paper being used?
          • romario
            • Jun 2020
            • 192
            Re: c7100ex color
            yes
            thanks
            • romario
              • Jun 2020
              • 192
              Re: c7100ex color
              yes, create paper profile to be able to print
              thanks
              • Warnock
                • Dec 2006
                • 50
                Re: c7100ex color
                Check your DV level toner for yellow, machine has tendency to break from torque. Your supply box from yellow could be culprit. big job.
                Programmers don't die, they gosub without return...
