RICOH Aficio MP C2050
  • ToBLeRoNe
    • Mar 2025
    • 7
    Hello,
    I have this type of mark on a RICOH Aficio MP C2050.
    Which component or part should I clean to resolve this problem?
    Thank you.
    Bonjour,
    J'ai ce type de trace sur un RICOH Aficio MP C2050.
    Quel organe, quel pièce dois-je nettoyer pour résoudre ce problème ?
    Merci.
    • 37488
    ITB cleaning unit
    Unité de nettoyage ITB
    • ToBLeRoNe
      • Mar 2025
      • 7
      Thanks.
      I cleaned the ITB CLEANING UNIT.
      It's in good condition, the squeegee is clean, but that didn't change the problem.
      The "fabric" roll is also in good condition.
      Merci,
      J'ai nettoyé ITB CLEANING UNIT.
      Elle est en bonne état, la raclette est propre, mais ça n'a pas changé le problème.
      Le rouleau en "tissu" est aussi en bonne état.
      • ToBLeRoNe
        • Mar 2025
        • 7
        Is this the Transfer Belt Cleaning Blade?
        Est-ce bien cela la Lame de nettoyage de la courroie de transfert ?
          • 37488
          Those three streaks are the ID sensor patches. There is no way they should still be on the ITB during a print unless the cleaning unit is not functioning correctly. Make certain that you are using a Genuine Ricoh part and not an after market one. Also make certain that it is for the C2050 and not for the C2051 as there is a difference.
          • ToBLeRoNe
            • Mar 2025
            • 7
            I've had this copier for several years; the part is original and has never been replaced.
            Do I need to replace this part?
            Do you think cleaning it is not enough?
            J'ai ce copieur depuis plusieurs années, la pièce est d'origine et n'a jamais été changé.
            Je dois changer cette pièce ?
            Un nettoyage n'est pas suffisant d'après vous ?
              • 37488
              The ITB cleaning unit should be replaced ever 60K for a machine that is used within the targeted monthly usage of 8K to 50K. If under utilized then it needs to be replaced after one and a half to two years. The blade material will soften with age.
              • sandmanmac
                • 3981
                Yes. Replace that unit
                • sandmanmac
                  • 3981
                  Yes.
                  Replace the unit
                  Think of it like the wiper blades on your car.
                  They may still look good, but not clean worth a damn
                  • ToBLeRoNe
                    • Mar 2025
                    • 7
                    Thank you all for your help. It's very helpful and your explanations are clear.
                    Can I replace just the blade, or is it better to replace the entire unit?
                    I'm having trouble finding a website that offers official RICOH products. Can you help me?
                    Merci pour votre aide à tous, c'est très agréable et vos explications sont clairs.
                    Puis-je remplacer que la lame, ou c'est mieux de remplacer l'unité entière ?
                    Ensuite, j'ai du mal à trouver un site proposant des produit officiel RICOH, pouvez-vous m'aider ?
                    • davel
                      • Oct 2011
                      • 1104
                      Good luck, very old machine. Ricoh Australia still had them 5 years ago.
                      • sandmanmac
                        • 3981
                        • ToBLeRoNe
                          • Mar 2025
                          • 7
                          Hello,
                          If I only print in black and white, once the transfer tape is clean, I no longer have any streaks. But only in black and white.
                          Could the problem be elsewhere?
                          Bonjour,
                          Si j'imprime qu'en noir et blanc, une fois la bande de transfert propre, je n'ai plus les traces. Mais seulement en noir et blanc.
                          Le problème peut-il être d'ailleurs ?
                            • 37488
                            That is because color alignment, the diagonal lines of the ID patches, does not need to be done.
                            • ToBLeRoNe
                              • Mar 2025
                              • 7
