color pcu mpc3004 in mpc3003
  • Mark Bbb
    • Jun 2012
    • 1662
    I have replaced a mpc3003 pcu with a mpc3004 pcu D2392239, as some treats here assume that it works fine.
    But here it won't fit.
    Surely there must be an adjustment made to fit it with the dev unit?
    Thank you in advance.
    Greetings,
    Mark
  • GIUBOSS
    • 1443
    Re: color pcu mpc3004 in mpc3003
    Greetings,
    Mark
    like the other ricoh pcdu units you have to swap the sensor td (connector and cable), if it does not fit completely make a comparison with the original one
    • Gift
      • Mar 2011
      • 2456
      From what I recall you can only use the 04 drum unit for 03 series, not the entire PCU.
      • Mark Bbb
        • Jun 2012
        • 1662
        Strange that some technicians here tell us in previous treats that this pcu mpc3004 fits in a mpc3003, because that is totally not the case!
        • copier tech
          • 8284
          Yes I have heard this too, the MP C3004 black PCU is cheaper & fits the MP C3003 black. But not confirmed this myself.
          • Mark Bbb
            • Jun 2012
            • 1662
            Dear C.T., i mean the color pcu.
            For BK that is it could be, I haven't tried that out yet.
            • tsbservice
              Field tech
              • 8112
              Mark see below. Looks like black Cxx04 will fit everywhere.
              Imho all kudos should go for skynnyb.
              P.S. forgot to add thread quoted
              Will a MPC2503 fit inside a MPC3503?
              Originally posted by FrohnB
              Okay! Tested this out today. The Black Cxx04 (D2392243 - current number) does indeed work in the color slots for the C3004 - C6004 and the C3003 - C5503! At $102.00 per drum (400k yield) instead of the color xx04 drums at $267 (175k) or $451 (270K), or the $950 xx03 drums , we are going to start using these. Will make it a little easier on the car stock also.
              Thank you guys for all the great info!
              Originally posted by fshead
              when you swap in new drum do you much around with the lub bar spring?
              Yes. We do this no matter what. It would be dumb not to. They say "not to do this procedure" for the C3003/C3503/C3004/C3504, but we say screw that. Moving that spring is what gives those drums such a high lifetime (usually way over yield). Not moving the spring gives that drum anywhere from 1/10th to maybe 1/3rd expected yield. ALWAYS MOVE THE SPRING!
              Originally posted by skinnyb
              Yes and vice versa. Color pcu fits black slot and vice versa too. I put a color 03 pcu (D1862229) in a black 4504 slot the other day cause that was the only one I had in Stock. So the black 04 all around is cheaper. And the charge roller even better. I carry both. The dev units are the only noticeable difference and even then it's only on the front and the plug.
              Sent from my LM-V405 using Tapatalk
