Ricoh Pro C5110s
  • 787print
    • Dec 2021
    • 6
    Ricoh Pro C5110s
    Hello new here!
    We have a Ricoh Pro C5110s that is giving an Error: Replace Photoconductor Unit Cyan / No Lubrication
    We have replaced it for all colors but still giving the message.
    We have reset the counters on the SP Mode but still maybe we're missing a reset not sure its been a week not sure what to do.
    This is an old printer, Ricoh where i live is no longer service it.
    I appreciate your feedback!
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh Pro C5110s
    Execute SP7622-xx for the part you are replacing. If it refuses to reset, there is a problem with the lubricant near end detection switches in the cleaning unit itself.
    Hit it.
      • 37365
      If I remember correctly, SP 3810-021/022/023/024 depending on the color will give the reason for lubricant bar end detection.
      0 is what you want to see
      1 is mechanical detection
      2 is near end detection (by lube bar counter)
      3 is detection (by lube bar counter)
      If it is 1, you know immediately that there is a problem with the lubricant near end detection switches.
      Attached is a bulletin on the switch problem.
      rfg070818.pdf
      • dalewb74
        • Feb 2018
        • 1126
        did you replace the Drum Coating Bar Assembly?
        • copier tech
          • 8132
          Originally posted by 787print
          Hello new here!
          Are you sure this is the correct message "Replace Photoconductor Unit Cyan / No Lubrication?"
          Did you consult the service manual before & after replacing any parts?
