mpc3002 auto firmware download - error
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    Best wishes (witches ) for you in 2022.
    May it bring you lot's and lot's of big problems we could solve here .
    While it was remotely updating the firmware (on a mpc3002 for smears), someone sended a print job.
    I clearly had informed customer not to do so, but you know...
    Machine now keeps asking for firmware.
    "connecting for firmware" .
    No entering sp mode or user mode, just this message appears.
    Replace NV ram?
  • DRichard
    • May 2008
    • 482
    Re: mpc3002 auto firmware download - error
    Originally posted by Mark Bbb
    Hoi,
    Replace NV ram?
    If you haven't already tried this. Have them turn the power off, unplug both the power cord AND the ethernet cable for about 5 minutes, then turn it back on. There's a good chance no damage was really done (of course it's never good practice to interrupt firmware updates). Then make sure the network cable has been disconnected before another attempt is made. I never panic as a first response.
    Good luck.
    "Enjoy every sandwich."
    -- Warren Zevon
    • mikadonovan
      • May 2008
      • 2931
      Plan "B" might be to prepare a sd card with the firmware on it and try to recover onsite.
      NEVER ASSUME ANYTHING
      • copier tech
        • 8132
        Hoi,
        Replace NV ram?
        Update the firmware using an SD card. (unplug the lan cable first obvs)
        • DRichard
          • May 2008
          • 482
          Definitely my preferred method. I don't like remote or scheduled updates for this very reason...but I understand it is sometimes necessary.
          -- Warren Zevon
          • anothertech
            • 1760
            Try this,
            Press "1","4","3" using the number keys while the error code is displayed. 2) Press the "CLEAR" key 3 times. 3) Once the error is cleared, the machine will indicate this with beep.
            Then reboot.
            • Mark Bbb
              • Jun 2012
              • 1662
              Originally posted by anothertech
              Try this,
              Then reboot.
              No luck...
              • Mark Bbb
                • Jun 2012
                • 1662
                Thank you all guy's for your help, makes life much easier .
                Can someone please provide me with the latest firmware mpc3002?
                I have an Octopussy account but I can not enter it because: "your computer is to old"
                (Probably the ram or processor not powerful enough.)
                I promise i'll buy a new (second hand) soon...
                  • 37326
                  More likely it is the OS version of your computer. I know that Ricoh-USA no longer has drivers specific for anything prior to Win 8.1, MAC OS X 10.12 or Windows Server 2012.
                    • 37326
                    Another thought, it could be the version of .NET that Octopus requires. Octopus 2018.5 and later requires.NET Framework 4.5.2 or newer and WMF/PowerShell 5.0 or newer.
                    • copier tech
                      • 8132
                      I have a 10 year old battered laptop it can access "Octopussy" no problem. I use Chrome browser.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Can someone please provide me with the latest firmware?
                        Or is it possible to merge the firmware from another mpc3002 to an sd card (this info is not in the manual (merging is, but it moves from sd card to sd card)), probabely that is not possible?
                        • copier tech
                          • 8132
                          Happy to help with the firmware.
                          Printer & Copier Firmware - www.printerfirmware.co.uk
