RICOH MP C3002 SC120-00
  • Maged_elagamy
    • Mar 2021
    • 42
    [Error Code] RICOH MP C3002 SC120-00
    I had an usual call from a usual client with an error SC 120
    well ! i thought it will be an easy task
    just clean the HP sensor and some mirrors
    but it turned to a nightmare
    the service say it's a Scanner Home Position Error
    here is what i did :
    checked and replaced scanner motor / HP sensor / harness / scanner board
    timing belt, pulley, wire, and carriage are installed correctly
    is there any thing else to consider ?
    next time i will replace the exposure lamp and i know it's not the problem
  • anothertech
    • 1771
    Re: RICOH MP C3002 SC120-00
    When you turn the machine on, dose the scanner move to the home position?
    Did you check the sensor and motor in input/output mode?
      • 37532
      Does mean that you actually replaced the scanner head carriage wires? If so did you use a set of Scanner Positioning Pins to make sure the lamp carriage and mirror carriage were properly aligned? If not the front end of the mirror carriage could be hitting the frame before the rear reaches the home position sensor.
      • Maged_elagamy
        • Mar 2021
        • 42
        The scanner moves to home position as normal and the error appears after 20 seconds
        No I didn't check them in input /output mode
        But i already replaced the sensor
        • Maged_elagamy
          • Mar 2021
          • 42
          No i didn't replace the wire but i checked the motor is running normal and wire , pulley and carriage seems fine and normal
          The client said the error occured suddenly when copying some papers via adf
          • anothertech
            • 1771
            Try it in I/O mode to see if the sensor signal is getting back to the board.
            • Mark Bbb
              • Jun 2012
              • 1662
              Was there a power failure between now and 2 months ago?
              • GIUBOSS
                • 1436
                Try starting the MFP without the adf ...
                • Maged_elagamy
                  • Mar 2021
                  • 42
                  No
                  • Maged_elagamy
                    • Mar 2021
                    • 42
                    I did but nothing changed
                    • DRichard
                      • May 2008
                      • 482
                      I don't think you mention wiring harnesses? (from the manual...)
                      Scanner home position error 1The scanner home position sensor does not detect the "OFF" condition
                      during operation.
                       Scanner motor driver defective
                       Scanner motor defective
                       Harness between SIO board and scanner motor disconnected
                       Scanner HP sensor defective
                       Harness between SIO and HP sensor disconnected
                      1. Check the cable connection between the SIO board and scanner
                      motor.
                      2. Check the cable connection between the SIO and HP sensor.
                      3. Replace the scanner motor.
                      4. Replace the HP sensor.
                      My apologies if this looks redundant.
                      "Enjoy every sandwich."
                      -- Warren Zevon
