RICOH SP C361sfnw
  • pinkyman
    • Jun 2022
    • 33
    RICOH SP C361sfnw
    hello everybody .. i've ricoh sp c361sfnw it working good print and scan Lan and usb but wi fi didn't work when i make it on doesn't work and not active ... it all off wi-fi and direct wi-fi .. just Lan only .. i try to enter sp mood 806182 and execute 5846-46 and restart the machine but it didn't work .. i try to enter sp mood by reset-143-C C and execute 5846-50 but also didn't work
    what can i do ?? will installing firmware fix this problem ??? and will someone here have the rom file ??
    • 37488
    That is because it does not have a full built in WiFi interface from the factory. It was an available add on that cost a few hundred dollars US. The option required the use of a really ugly external antenna. WiFi Direct is very short range intended for use with the Ricoh Connect app on your cellular device.
    If you want to print using your building's wireless network what you need to do is a wifi range extender. The LAN port on the extender that is used for setting it up can then be connected to the MP C LAN port.
    • pinkyman
      • Jun 2022
      • 33
      so it's a hardware problem .. there's no wi-fi device in the machine .. can i connect a wi-fi usb adapter to the machine via usb in the machine so can the wi fi in the machine work
        • 37488
        No because you have no way to configure it.
        • patterson70
          • May 2010
          • 599
          Normally this machine has built in Wi-fi, the "w" means Wi-fi and the pics you sent show it does have it. I do not see where you says it is not active however, the pics don't show that.
          If it is inactive then there is something wrong with the machine that you have to research further. It does not have the strongest signal, the antenna is internal and cannot see the router unless fairly close. Maybe try moving the machine close to the router if it is not close already and try to connect it.
            • 37488
            If it has built in wireless then it is not a service setting through SP mode of any type. It is enabled through what used to be User Tools - System Settings - Interface - IEEE 802.11
            • Daniel_B81
              • Jan 2019
              • 43
              I wonder if it isn't that you're trying to configure the panels WiFi-function, don't have any operational 360 nearby but if i'm not mistaken the easiest way to configure the correct WiFi-card on that machine is from User Tools -> and a menu that is called something like Basic Installation for initial setup and you have a Network-cathegory there where you pick if you are using wire or wired connection.
              • dalewb74
                • Feb 2018
                • 1153
                i agree with slim, as always. it says wi-fi, but it doesn't function as what we think of as wi-fi. i have never had luck to get it to work. even if you manage to get it turned on. it has no range. it is junk. they shouldn't even have it on the machine. it is more headache than its worth, total waste of time.
                as slim suggested. use the wi-fi in the building and an extender. or if there is a network connection in that room. just plug it into the copier. took long enough, but most of the copier brands i deal with have finally decided to start adding true wi-fi within the last few years. though i haven't seen it on the ricoh yet.
