Ricoh mp c6501
  • htb2k5
    • Aug 2009
    • 22
    Ricoh mp c6501
    Ricoh mpc6501 in sometimes has lines in red, blue, yellow (black does not) as shown.
    Paper goes sideways, short.
    Note that code 3501 will fix if you choose to fix it, and if you choose auto it won't.
    Choose a more beautiful, bolder fix
    Hope you can help. Thanks
  • anothertech
    • 1769
    Re: Ricoh mp c6501
    Looks like charge or dev bias arc, disassemble color units and vacuum out and clean drum, dev, charge, cleaning units.
      • 37488
      Re: Ricoh mp c6501
      Looks like either a dirty charge roller or a nick on the cleaning blade in the magenta PCU. Check PM counters. You may need to rebuild the PCUs. The C6501 can be a major toner belching beast if you do not keep them maintained properly.
      • htb2k5
        • Aug 2009
        • 22
        Re: Ricoh mp c6501
        if sp3501-1 = 0 (auto) then it didn't always show magenta,yellow,cyan streaks
        if sp3501-1 = 1 (fixed) then it has occasionally appeared magenta,yellow,cyan streaks
        • htb2k5
          • Aug 2009
          • 22
          Re: Ricoh mp c6501
            • 37488
            Re: Ricoh mp c6501
            Process control should only be set to fixed when the ID sensor assembly is bad, needs to be replaced and you have to wait for the new one to arrive.
            • mikadonovan
              • May 2008
              • 2931
              Re: Ricoh mp c6501
              This is a fact. There is even a bulletin out about replacing the color lube bars at 150K or streaks/lines will occur, and they're not kidding. I do not miss working on this model. At least 1 service call a week.
              NEVER ASSUME ANYTHING
              • Brianneoe
                • May 2015
                • 318
                Re: Ricoh mp c6501
                There are some machines you should walk away from even if you have a ton of experience with it..this machine is one of them. I posted a long rant about this unit awhile back on CTN and you may want to look at it if you decide to go forward with this repair. Some units are not worth repairing.
                Happy New Year!
                  • 37488
                  Re: Ricoh mp c6501
                  There is a laundry list of bulletins dealing with toner scattering and light density.
                  Happy New Year!
                  It can be made to work quite well but it is going to require some work and initial cost.
                  1. Bring all firmware up to current
                  2. Apply all service bulletins
                  3. Rebuild all PCU and replace all developers, do not use after market parts or developer
                  4. Apply the changes listed in the attached document
                  • Zaxxon
                    • 608
                    Re: Ricoh mp c6501
                    Totally agree, even though it will kick your balls! Every single PM ends with a Sc...
                    Run Forest!
                    Please start you post with brand, model, problem.
                    • tsbservice
                      Field tech
                      • 8013
                      Re: Ricoh mp c6501
                      Originally posted by Zaxxon
                      ... Every single PM ends with a Sc...
                      Lol... ouch! Sounds like a lot of fun 😁 in the is always you against the beast.
                      I used to like lemon Toshibas after they initially beat the cra. out of me eventually making them MY bitches
                        • 37488
                        Re: Ricoh mp c6501
                        Run Forest!
                        Ever one that I applied the changes in that document worked fine there after and continued to work fine for 5 years until the customers traded them in on newer models.
                        • htb2k5
                          • Aug 2009
                          • 22
                          Re: Ricoh mp c6501
                          Happy New Year!
                          Thanks!
                          • anothertech
                            • 1769
                            Re: Ricoh mp c6501
                            I never could get those monsters to behave. I wish I would've had that document years ago during the battles.
                              • 37488
                              Re: Ricoh mp c6501
                              I had to install a couple at a national account that we serviced and I was not scheduled for training until a few weeks later. The western regional dealer support engineer came to Bakersfield and trained me. He gave that. The settings lower slightly the toner concentration in the developer and corrected the affect on image quality by increasing the transfer to both the drum, the ITB and the paper. Less toner in the developer meant less scattering and extended toner cartridge life. Greater percentage of the toner that went onto the ending up on the printed page meant less waste toner.
