MP2501 with PB2000 Jam 17
  • Codex
    • May 2008
    • 705
    hello guys
    i'm gone mad today with a Mp2501 with PB2000 tray unit, the machine jams with J17...checked clutch, feed motor, changed Feed roller and separation pad...nothing jams everytime from tray 2 (A3), tried to change size to A4, same problem!! Any ideas?? Thank you!
    Memento Audere Semper
  • Gift
    • Mar 2011
    • 2459
    Re: MP2501 with PB2000 Jam 17
    Funny I don't see J17 in service manual:
    7504
    [Paper Jam Loc] Paper Jam Location (D158/D159)
    Displays the number of jams according to the location where jams were detected.
    001 At Power On *CTL
    003 Tray1: On *CTL [0000 to 9999 / - / 1 / step]
    004 Tray2: On *CTL [0000 to 9999 / - / 1 / step]
    005 Tray3: On *CTL [0000 to 9999 / - / 1 / step]
    006 Tray4: On *CTL [0000 to 9999 / - / 1 / step]
    008 Bypass: On *CTL [0000 to 9999 / - / 1 / step]
    009 Duplex: On *CTL [0000 to 9999 / - / 1 / step]
    018 PFU1: On *CTL [0000 to 9999 / - / 1 / step]
    019 PFU2:On *
    Does the paper move at all or is it some kind of "no feed" jam?
    • Codex
      • May 2008
      • 705
      7504
      019 PFU2:On *
      maybe J17 appears only with the PB2000?, the paper stops on the first sensor coming out from tray 2 (tray 2 is optional, the machine comes with only tray 1)
      • Gift
        • Mar 2011
        • 2459
        Ok, can you test that sensor via Input check?
          • 37560
          Is it the first page out of the tray or later in a multi-page run. If the 2501 has a 1 bin exit tray, according to Goose's guide, J017 is a 1 bin tray exit jam.
          • Codex
            • May 2008
            • 705
            Hmmmm... It happens only with tray 2...but the strange thing is that the Pb2000 comes as a 3rd tray, but in this machine for some reason its the second tray (machine have only one tray)... Can this be the problem?.. And yes.. It jams on the first page
            Inviato dal mio SM-G935F utilizzando Tapatalk
            • Codex
              • May 2008
              • 705
              Tomorrow i'm back there and i'll try input check
              • luca72
                • Oct 2017
                • 1791
                hello guys
                hi, try to do this, (on the mp2000 it was easier, there were square holes on the frame)
                disassemble the plastic to the vertical right of the duplex (looking at it from the front) or the rear panel, you will find where the feeler of the passage sensor comes out, and its sensor, and give a good blow, it gets very dusty, do the same thing with that of passage, behind the metal guide, behind the duplex
                however, try to activate the clutch with output check, and try to make it slip with your hand, if you see that it slips with the utmost ease, it is gone, if instead it offers good resistance, then it's ok, maybe you have to keep the drawer switches pressed , I do not remember well
                "I'll be back"
                • Codex
                  • May 2008
                  • 705
                  Thank you! I'll try this and let you know.
                  Inviato dal mio SM-G900F utilizzando Tapatalk
