Ricoh C4504ex Print jobs are not printing, Authentication Failure
  • Jinn
    • May 2023
    • 120
    Hi Experts,
    I am facing a strange problem. Whenever I send a print job the machine receives, it gives a processing sound, a loud beep and then stops. When I checked in the printer logs it shows" Authentication Failure" You do not have privileges to use this function. The job is cancelled.
    I have checked through WIM and could not find any authentication active. No user authentication no windows authentication but still its behaving strangely.
    Is there any option, Switch or setting to turn this authentication off ?
    Thanks in advance
    Regards
    • 37444
    It might not be a setting on the C4504. Make sure that the driver setting for user name is not set to one of the administrators, and that includes supervisor. Administrators have rights ONLY to machine settings and not to functions.
    • Popolopo
      • May 2023
      • 126
      Try check admin authentication in user tool, admin tool. But if you got user, don't turn it off. Need to follow what slimslob recommend to do.
      • Saturn
        • Nov 2023
        • 171
        Export the the device settings and after that, erase all memory to see if the problem is gone. If not, you can restore the device settings and keep on looking for the reason.
        I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
        • sandmanmac
          • 3981
          Originally posted by Jinn
          Hi Experts,
          Thanks in advance
          Regards
          Is this any/ all Pc's/ laptops that are connected, or just one?
          What happens if you connect your own laptop
          • Jinn
            • May 2023
            • 120
            The driver settings are default. No authentication is anbled or Set. If I connect another machine of the same model it prints instantly. Using the same drivers. I believe there is something wrong with the machine. Some security or authentications.
            • Jinn
              • May 2023
              • 120
              I connected my own laptop directly with the machine. If I connect other machine of the same model, assign the same IP and use the same drivers for it, it prints. But this one gives long beep and stops. Upon checking the log you will see job cancelled. Authentication failure.
              • Gift
                • Mar 2011
                • 2459
                Some time ago there was several machines turning on a function called "IEExxxx Authentification" (somewhere in admin settings) by itself leading to weird issues - IIRC it was not possible to enter the WIM though but you miight check. Otherwise I'd go and reset system settings to factory default as suggested. Some sort of function restriction must be anabled on that machine.
                • Jinn
                  • May 2023
                  • 120
                  I am going to erase memory. There is another option showing "ERASE HDD" and there are some types to select. Its by default set on " Random Numbers"
                  What to do here
                    • 37444
                    What to do here
                    It has to do with the level of security. Similar to DOSS, Data Overwrite Security System.
                    • Jinn
                      • May 2023
                      • 120
                      I selected "Format HDD" and execute memory clear. After that machine restarted and its printing now. Now should I import the old data back to the machine or keep using as it is?
                        • 37444
                        Six the one half dozen the other. There is the chance you could recreate the problem but then is there anything in the old data that you need that is not backed up somewhere else.
