RICOH SCAN WIM Document folder slow
  • aviso66
    • Dec 2012
    • 202
    [Misc] RICOH SCAN WIM Document folder slow
    Hi, is there anyway we could make access to ricoh scan to WIM\ Document folder any faster? Bec it's just damn slow.
    is there anyway we could do network mapping the document server onto our computer like a network drives?
    • 37532
    Re: RICOH SCAN WIM Document folder slow
    What Model Ricoh are you talking about? Are you asking about to scan to a Document Server folder and then retrieving it through WIM? If so which part is slow, the scan or the retrieval? Why can't you just do SMB scan to folder or Secure FTP? With most Ricoh models there is also scan to memory device.
    • aviso66
      • Dec 2012
      • 202
      yup scan to doc server and retrieve from wim.
      scan to smb doesnt work and if using FTP will require fixed ip not recommended for laptop.
      scan to memory device can be an alternative.
        • 37532
        Once again what model Ricoh do you have? Depending on the model it might support SFTP or FTPS to Host Name. Also depending on model it might also support scan to cloud drives.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Regardless of model, scanning to the doc server and retrieving from there will not be an option unless you have the file converter board installed. Extremely limited download capability without it.
          This is not firmware or software, but actual hardware.
          Not likely, as you would know it if the option was there.
          • MIGUELMARCHENA
            • Feb 2018
            • 195
            What are your reasons for not using smb, email or ftp?
            there are clients who have very old machines and use external scanning programs...as happens with epson, hp, etc.
            but you can use smb ftp or email for whatever reason,
            Instead of using wim scan, you are better off downloading the twain, and any other scanner program.
              • 37532
              Until he tells us what the model of the Ricoh is, it could be a full laundry list of potential items.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                • luca72
                  • Oct 2017
                  • 1784
                  he doesn't want to say it ... not even under torture .. LOL
                  "I'll be back"
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
