IM C400F
  • SCOTTSMILEY
    • Dec 2023
    • 7
    IM C400F
    I have a doc feeder bending both corners but not jamming... Any ideas??????
  • luca72
    • Oct 2017
    • 1708
    usual problem of those RDF of shit, open the back cover, tighten the hinge screws, and put some epoxy resin over the screws, wait for it to dry
    if you're lucky the plastic hasn't stripped
    p.s. exist a ricoh repair kit but cost over 50 euro for 2 piece of metal and two screw...crazy!
    "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
    • SCOTTSMILEY
      • Dec 2023
      • 7
      THANKS
      • luca72
        • Oct 2017
        • 1708
        THANKS
        Check First if the plastic hasnt not stripped, you only could Need replace It with the screws a Little more large in this case...not too, because you could brake the plastic
        • copier tech
          • 8117
          See attached bulletin, this works well.
          ADF Hinge Break.pdf
          • jumpinj18
            • Oct 2023
            • 9
            I filled holes with JB weld and it seems to be working fine. Hinges really do suck.
            • luca72
              • Oct 2017
              • 1708
              and think that even now, they are still like this!
              a bit it is also the client who lifts it too violently, it seems like they do gymnastics with the rdf....lol
