Hi everyone,
I’m using a Ricoh MP C4503 with a SR3160 finisher, and I’m getting the error SC720-71 at startup.
Here’s what happens:
Some things I’ve tried:
My questions:
Any suggestions or steps to troubleshoot this would be greatly appreciated!
Thanks in advance for your help.
- When the machine starts, it makes a bit of noise while the shift tray is moving up.
- Right after that, the SC720-71 error appears.
- I’ve noticed that the stapler mechanism seems to be moving in a strange way, but I’m not completely sure it’s the cause.
- I released the belt/cord that drives the right-side gears (where the door is located).
- I also released the shift tray, and it seems to sit correctly on both sides.
- When I manually rotate the motor (with the machine off), everything appears to move smoothly — no apparent blockage or misalignment.
My questions:
- What is the "home position" for the shift tray?
Since I moved it manually while testing, I’m not sure if it's still correctly aligned. - Is there a way to test the tray movement sensors (those that check the tray position/timing on one side) to confirm if they are working correctly?
- In your experience, is it more likely to be a sensor issue or a motor problem for this type of SC720-71 error?
