Red lines during color copy only MPC4501
  • PaulDuner
    • Feb 2022
    • 8
    Hey all,
    Ricoh MPC4501 produces light red lines during color copy. Color print is fine. B/W copy is fine.
    Ex. I print a color test pattern, it prints fine. I take that same page and color copy, it prints light red lines horizontally across the page. Of course, a B/W copy of same page is fine.
    It seems like a scanning issue to me but not sure what what to look for or adjust.
  • luca72
    • Oct 2017
    • 1778
    Re: Red lines during color copy only MPC4501
    Originally posted by PaulDuner
    Hey all,
    clean the optic mirror
    clean laser glass
    some bit particle of powder can create strange color refraction.
    if no ok, clean the magenta drum charge roller with a rag with 2 drops of hand soap and water, with very gently movement, for not scratch the extreme delicate surface
    "I'll be back"
    • anothertech
      • 1769
      Clean the small strip of glass just to the left of the big main glass that you lay documents on to copy.
        • 37489
        That's called the Slit Glass. Common cause is someone that has marked an original with a Pilot or other make gel pen and not allowed sufficient time to full dry. Very common problem. Alcohol prep pads work great for cleaning.
        • PaulDuner
          • Feb 2022
          • 8
          I should have stated that in the original post. I have thoroughly cleaned the slit glass (ADRF) and the main glass (single sheet). Red streaks occur on both glass locations.
            • 37489
            That sounds like a speck of magenta toner on a mirror.
            • luca72
              • Oct 2017
              • 1778
              But, you have cleaned well also the internal optic mirror, on carriage?
              "I'll be back"
              • anothertech
                • 1769
                99% of the time it's on the slit glass, but there is that 1% of the time that it's on the mirror.
                • PaulDuner
                  • Feb 2022
                  • 8
                  Correct. I removed the glass. Moved the optic carriage over and cleaned both mirrors. No change.
                  Here is the odd thing. When I was cleaning the mirror I see the adhesive used to "glue" the the first mirror to the second mirror. I figured that was the problem but I opened up my spare parts machine at my office and it is the same way.
                  • luca72
                    • Oct 2017
                    • 1778
                    he says he does the problem, in both positions of the glass (I assume it means, slide and exposure plane), however, I do not know if it is the translator who does not perform well, but I have as the perception, that he has only cleaned the glasses from outside... LOL.... it would be the maximum of the maximum... LOL...LOL
                    "I'll be back"
                    • luca72
                      • Oct 2017
                      • 1778
                      try to make a significant magnification and reduction, see if the lines move
                      "I'll be back"
                        • 37489
                        Your picture is taken from the backside of the 2nd carriage. The mirrors are not glued together, they are held into the carriage with retainer spring clips, one at each end of each mirror. If you cleaned the side of the mirror toward the camera, you cleaned nothing. Mirrors in copiers are always First Surface mirrors. Be very careful when cleaning first surface mirrors as you are actually cleaning the reflective coating which is easily scratched. There are also 3 mirrors, 2 on the 2nd carriage and one on the 1st carriage.
                        • anothertech
                          • 1769
                          Give a shot of air to the CCD also.
                          • emiliorsg
                            • Jul 2018
                            • 141
                            Clean the mirror located in the carriage and the exposure lamp too.
                            • PaulDuner
                              • Feb 2022
                              • 8
                              Solved! Well, believe it or not. It was the magenta drum. I can't understand why it only does it when doing copy and not during print. Maybe the way the image is processed??? Thanks for the help.
