Color stripe (1 cm) on top edge of page.
  • ThomasM
    • Feb 2022
    • 12
  • Allannmm
    • Feb 2022
    • 1
    Re: Color stripe (1 cm) on top edge of page.
    Check magenta pcu change cleaning blade.
    • davel
      • Oct 2011
      • 1107
      Old machine, get a trained tech to service it.
      • sandmanmac
        • 3981
        Originally posted by ThomasM
        [ATTACH=CONFIG]52223[/ATTACH]
        It's not so much the "40K pages" as it is the 14 years old, combined with number of drum "rotations".
        With only 40K copies , this machine must have done A LOT of 1-2 page jobs, which reduces the consumable yields. I relate it to City miles Vs. Highway miles on a car.
        So it needs a magenta drum unit - at minimum
        As for the "stick", that is not cleaning the drum. it is used to clean the laser slit glass for each drum unit. Most often due to toner particles falling onto the surface -which will create BLANK bands - NOT smearing. So it would have just ben coincidental that you say it was fine.
        The drum cleaning can come and go a bit and often is not so bad on the first few pages, but gets consistently worse.
        • Gift
          • Mar 2011
          • 2459
          14yo lol - cleaning blades are probably hard like "sticks" too, compare with 14yo windshield wipers on a low mileage car....
          • luca72
            • Oct 2017
            • 1784
            if it is true that it only has 40k prints, it must only be lucky, taking it apart and drums are really "strong" you can even do three laps!
            do some crossing of parts at zero cost, with the yellow drum.
            I personally think it is an accumulation of dust and toner in that area of ​​the cleaning blade and / or the charge roller to be washed well with soap and water
            "I'll be back"
              • 37533
              In addition to small page count jobs, The color PCU pick rotation counts every time process control is ran. For most machines that is at least once a day. In 14 years that is hell of a lot of wear on the drums, cleaning blades and the lube bars.
              • ThomasM
                • Feb 2022
                • 12
                Thanks for all tips.
                Anyone have a link to a parts catalog?
                Found one but can't remember where.
                All I can find now is the one from Ricoh University in 3D whith colors and that parts catalog sucks...
                Trying to find correct parts numbers for cleaning blade and lubrication blade.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Just change the PCU's. D039 2040.
                  Hit it.
                    • 37533
                    Ricoh does not sell those as separate items, never have. You have to order the PCU, drum unit, as TonerMunkeh says.
                    • COPIERMAN
                      • Jun 2009
                      • 559
                      compatible drums and blades work try copylite or katun also, on tube there is a guy from Russia show how to take it apart. if you are a tech should be no problem.
                        • 37533
                        As long as you don't damage the contact spring for the charge roller. If you do, you then have a big problem. Been there, done that.
