ricoh IM C300 SETTING ICON missing
  • gilbert
    • Oct 2017
    • 38
    [Misc] ricoh IM C300 SETTING ICON missing
    Hi friends
    I need your help. I have IM C300, I have replaced a broken
    operation panel and later discovered that SETTING icon is missing
    what could the issue.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ricoh IM C300 SETTING ICON missing
    Did you change the entire panel or just the touch screen? It may be the apps weren't loaded on the new screen.
    Hit it.
    • gilbert
      • Oct 2017
      • 38
      i changed entire panel
      • Gift
        • Mar 2011
        • 2459
        Did you re-flash the firmware?
        • gilbert
          • Oct 2017
          • 38
          Yes i have just done firmware update.
          • TonerMunkeh
            Professional Moron
            • 3865
            Check the apps in panel SP to see if there is anything missing.
            Hit it.
            • gilbert
              • Oct 2017
              • 38
              still SETTING icon is missing any ideal what could cause this
              • Gift
                • Mar 2011
                • 2459
                Perhaps you have to be logged in as admin in order to see it?
                • gilbert
                  • Oct 2017
                  • 38
                  how?
                    • 37532
                    If you used Package firmware to "update" then any corrupted module was not replaced unless it was not the current version.
                      • 37532
                      Hi friends
                      Did you replace the entire SOP or just the Touch Panel?
                      If just the Touch Panel did you properly shutdown the IM C300?
                      • gilbert
                        • Oct 2017
                        • 38
                        Hi friends
                        y
                        This issue was resolved after replacement of controller board.
                        thanks
                        • Dreama
                          • Jan 2013
                          • 43
                          Wow - Control board and panel. nasty
                          • Gift
                            • Mar 2011
                            • 2459
                            kind of a write off in case you can't claim warranty.....
