Savin MPC3503 smart panel error
  • COPIERMAN
    • Jun 2009
    • 559
    when turning on copier as it comes up saying the application supply info widget (process jp.co.ricoh.advop.toner state) has stopped unexpectedly. Please try again.
    if you press icon Force Close then screen moves on to normal screen.
    i have gone into service mode and turn off toner supply icon but still comes up.
    Thinking need firmware for smart panel to fix problem. Any help will be appreciated
    thanks
    • 37560
    Re: Savin MPC3503 smart panel error
    thanks
    I believe it refers to the widget that is installed using the SOP Designer.
    • copier tech
      • 8195
      thanks
      Delete the toner icon widget & install the latest version & the latest cheetah panel firmware.
      • anothertech
        • 1771
        Try going into SOP service mode/apps/update/auto update
        Of course you need to be connected to the internet.
