I have successfully put MPC2504 toners in an IMC2500 with no modifications. IMC toners won't go into an MPC2504 without modification. My question is can MPC6004 toners go into IMC6000 machines without modification and also the MPC3004 into IMC3000 also. The toners in the MPC family are the same mix numbers as the IMC series. We are having problems getting IMC toners from Ricoh because of backorders ( what's new ) and I have plenty of MPC toners on my shelf. Thanks.
MPC Toners vs. IMC Toners?
Re: MPC Toners vs. IMC Toners?
Never tried, but I'd just keep the empties and swap the caps over.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
is your problem with them not going in all the way?
OR THE toner being seen by machine?
I had to mess around with the mpc3503 and mpc6003 series by using a dremel and blade to cut
underside of toner cap..
You can also buy chips and swap them when needed..Comment
I have successfully put MPC2504 toners in an IMC2500 with no modifications. IMC toners won't go into an MPC2504 without modification. My question is can MPC6004 toners go into IMC6000 machines without modification and also the MPC3004 into IMC3000 also. The toners in the MPC family are the same mix numbers as the IMC series. We are having problems getting IMC toners from Ricoh because of backorders ( what's new ) and I have plenty of MPC toners on my shelf. Thanks.Larhal
If all else fails read the Service Manual!
If that fails, meet me at the pub and we will discuss it.👍 1Comment
