Ricoh MP C3004ex & 4504ex ITB ROLLER Part Num required
  • Silverfoxraj
    • Apr 2012
    • 6
    Hi All,
    I was hoping to find the Part num for roller that fits the bushings D2416346 & D2416347 in the ITB unit. The roller part number isn't shown in the parts manual and i am sure the IMC 3000 IMC3010 series use the same part. We normally replace the bushings as necessary, however, we have had a few ITB belts snap and found the roller shaft worn.
    Thanks in Advance.
    This gallery has 2 photos.
  • dalewb74
    • Feb 2018
    • 1155
    have you looked in the parts finder?
    • semi
      • Sep 2008
      • 195
      Part is not available- I have asked Ricoh europe to add this P/N - Japan said there is no need, so you have to replaced the whole ITB unit
        • 8170
        If that roller is worn then chances are the transfer rollers are also worn out.
        Replacing the complete transfer unit will give you another 400k + prints.
        • Silverfoxraj
          • Apr 2012
          • 6
          Thank you all, will have to order the complete unit. Not really economical if more fail.
